wesleytaylor
Infered block ram warning [Synth 8-3514]
Getting the following error
[Synth 8-3514] cannot infer block ram on a non-memory variable 'RAM'
In my code
type ram_type is array (63 downto 0) of std_logic_vector(31 downto 0);
signal RAM : ram_type;
attribute ram_style : string;
attribute ram_style of RAM : signal is "block";  -- <-- Line where synth 8-3514 points to
Thanks for the help
Wesley
wesleytaylor
There is no reset for the RAM(0), RAM(1) signals.
They are concurrently assigned constants
RAM(63) <= x"C67178f2";
Therefore I believe my problem is the synth tool sees these as constants & not necessary ram.
After removing the block attribute I have removed this warning
anusheel
@wesleytaylor
We may not be able to comment by only looking at the memory declaration, can you share the small testcase/RTL file here?
What type of reset you are using?
Anusheel
Helpful answer -> Give Kudos
wesleytaylor
syedz
@wesleytaylor,
Glad to know that you have resolved the issue. You can check page number 99-100 in below Synthesis user guide for various RAM coding guidelines and Techiques:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug901-vivado-synthesis.pdf
As the issue is resolved, Kindly close this thread by marking the post as "Accept as solution".
--Syed
anusheel
@wesleytaylor
Yes, I guess you are correct. Removing attribute will clear your log, but if you want infer a BRAM for this memory logic you may need to change the RTL description.
Share your memory file here if you need any help in memory RTL.
Anusheel
