ogacns94
Infering one DSP48E for multiply and add opperation (round multiply) in ISE 14.7
Hello everyone!
I am constrained to using ISE 14.7 because I am using an old board that has a Spartan-3A and Virtex 5 FPGA. I am targeting Virtex 5.
I want to implement multplication with rounding of two fixed point numbers in VHDL that is mapped directly to one DSP48E block. By looking at the datasheet (https://www.xilinx.com/support/documentation/user_guides/ug193.pdf, page 14), this seems possible. I plan to do it by multiplying and then adding with a vector that has 1 in the possition needed for rounding:
A = 001011.11
B = 0110.1001
A*B = xxxxxxxxxx.xxxxxx
one = 0000000000.000100
A*B+one;
C =                   xxx.xxx
This is my VHDL code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity unsigned_round_multiplier is
generic(
IN0_INT_BITS : integer:= 4;
IN0_FRAC_BITS : integer:= 14;
IN1_INT_BITS : integer:= 0;
IN1_FRAC_BITS : integer:= 25;
OUT_INT_BITS : integer:= 0;
OUT_FRAC_BITS : integer:= 25
port(
in0_i : in std_logic_vector ((IN0_INT_BITS+IN0_FRAC_BITS)-1 downto 0);
in1_i : in std_logic_vector ((IN1_INT_BITS+IN1_FRAC_BITS)-1 downto 0);
out_o : out std_logic_vector ((OUT_INT_BITS+OUT_FRAC_BITS)-1 downto 0);
end unsigned_round_multiplier;
architecture rtl of unsigned_round_multiplier is
signal mult : unsigned((IN0_INT_BITS+IN1_INT_BITS+IN0_FRAC_BITS+IN1_FRAC_BITS)-1 downto 0);
signal round : unsigned((OUT_INT_BITS+OUT_FRAC_BITS) downto 0);
signal one_final_i : unsigned((IN0_INT_BITS+IN1_INT_BITS+IN0_FRAC_BITS+IN1_FRAC_BITS)-1 downto 0);
constant one : std_logic_vector((IN0_INT_BITS+IN1_INT_BITS+OUT_FRAC_BITS) downto 0)
:= (0 => '1', others => '0');
constant one_padding : std_logic_vector((IN0_FRAC_BITS+IN1_FRAC_BITS-1-OUT_FRAC_BITS-1) downto 0)
:= (others => '0');
attribute use_dsp48 : string;
attribute use_dsp48 of mult : signal is "yes";
begin
mult <= unsigned(in0_i)*unsigned(in1_i) + unsigned(one&one_padding);
out_o <= std_logic_vector(mult((OUT_INT_BITS+IN0_FRAC_BITS+IN1_FRAC_BITS-1) downto (IN0_FRAC_BITS+IN1_FRAC_BITS-OUT_FRAC_BITS)));
end architecture rtl;
ISE just won't map it to one DSP. Whatever I do, it is either mapped to two DSPs or to one DSP and a sequence of adders used from the slices. I tried adding a clock signal, separating it in two expressions, etc. It never maps it to one DSP only.
Does anybody have experience with this?
Thanks in advance!
