shyvana
Inferring Block Ram with Byte Wide Write Enable?
Hi, currently I am working on a MAC to AXI Lite interface and one part of the AXI Lite interface requires writes to include a byte wide enable on a 32 bit data bus. I was easily able to infer some block ram with a 32 bit data_in  port. I can't seem to find a way to include a write enable. Thanks.
This is the general template I have been using to infer dual port brams so far. If there is a better way I would love to know.
module bram_tdp #(
    parameter DATA = 72,
    parameter ADDR = 10
    // Port A
    input   wire                a_clk,
    input   wire                a_wr,
    input   wire    [ADDR-1:0]  a_addr,
    input   wire    [DATA-1:0]  a_din,
    output  reg    [DATA-1:0]  a_dout,
    // Port B
    input   wire                b_clk,
    input   wire                b_wr,
    input   wire    [ADDR-1:0]  b_addr,
    input   wire    [DATA-1:0]  b_din,
    output  reg    [DATA-1:0]  b_dout
// Shared memory
reg [DATA-1:0] mem [(2**ADDR)-1:0];
// Port A
always @(posedge a_clk) begin
    a_dout      <= mem[a_addr];
    if(a_wr) begin
        a_dout      <= a_din;
        mem[a_addr] <= a_din;
    end
end
// Port B
always @(posedge b_clk) begin
    b_dout      <= mem[b_addr];
    if(b_wr) begin
        b_dout      <= b_din;
        mem[b_addr] <= b_din;
    end
end
endmodule
arpansur
Hi @shyvana,
Please try with language template.
Arpan
Arpan
arpansur
Hi @shyvana,
Which device you are targeting? Is it from language templates?
Please go through page163 of following link to get more information on coding styles of RAM
http://www.xilinx.com/itp/xilinx10/books/docs/xst/xst.pdf
Arpan
Arpan
shyvana
Sorry for not mentioning 7 series, non US or US+.
No this was a template I found on stack exchange a long time ago.
Are there other templates?
arpansur
Hi @shyvana,
Arpan
Arpan
shyvana
Thank you very much! I never knew about this... well I probably just skimmed over it. I recently started using Vivado. Much appreciated.
arpansur
Hi @shyvana.
You are welcome :).
Arpan
Arpan
