Is VHDL 2008 supported by default in vivado 2016.4 ?
Hi ,
Is VHDL2008 supported by default in vivado 2016.4 ?
Is there an option to disable it ?
Re: Is VHDL 2008 supported by default in vivado 2016.4 ?
Hello @ewang. Please note that from Vivado 2016.x, the VHDL-2008 is switched on permanently.
By default read_vhdl command will take every .vhd files as normal VHDL, if user wants to compile the .vhd file as per 2008 then read_vhdl -vhdl2008 command should be used.
To switch off VHDL2008 from the script, you can use this command for this:
set_property FILE_TYPE {VHDL} [get_files *.vhd]
And to set VHDL on, use this command:
set_property FILE_TYPE {VHDL 2008} [get_files *.vhd]
If you want to see if VHDL-2008 is set or not, you can use ‘get_property…’ tcl command, e.g.:
get_property FILE_TYPE [get_files /home/test...../hdl/solus_top_struct.vhd]
...which will return either VHDL/VHDL 2008.
Hope this helps.
Anatoli
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @ewang,
Vivado 2016.4 synthesis supports a synthesizable subset of the VHDL-2008 standard.
Refer UG901 page.203: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug901-vivado-synthesis.pdf to get information on: Setting up Vivado to use VHDL-2008 and Supported VHDL-2008 Features.
Prathik
Hi @ewang
All the constructs in VHDL-2008 are not supported in Vivado 2016.4. You can disable it from the Vivado GUI by changin g the type as shown below:
Rohit
Rohit
If I want to switch off VHDL2008 from the script instead of GUI, what kind of variable or setting I should do ?
So by default, VHDL2008 is not enabled ,right ?
it needs "read_vhdl –vhdl2008" to enable it ?
Hope this helps.
Anatoli
Kind Regards,
Anatoli Curran,
yes its supported by default
Thanks and Regards
Balkrishan
Hi @ewang,
Can you please mark the appropriate post as an answer "Accept as solution" in case it helped resolve your query?
This will help other users in future looking for the same query with an accepted answer.
It will also close this thread.
Thanks & Regards,
Prathik
Hey Anatoli,
is there a possibility to use a shebang line or something like that.
I import .vhd files from an external git repository to several projects, it would be nice to specify the vhdl type within the flle.
Franz
Is it possible to treat all VHDL files as 2008 by default in Vivado 2018.1 ?
Using the GUI workflow I can select VHDL-2008 in the properties window of a .vhd file individually.
Is there a possibility to configure Vivado to treat every .vhd file as VHDL-2008 by default ?
Maybe the solution is in the posts above but I'm relatively new to Vivado and don't know which script to modify to make the VHDL-2008 setting permanent.
Re: Is it possible to treat all VHDL files as 2008 by default in Vivado 2018.1 ?
I would second that question...
Thomas
If you are intending to use the IP Packager (eg to use your VHDL as part of a block design), be aware that these do NOT support VHDL-2008. I have just had to spend a whole day removing all the VHDL-2008 constructs from my current project because of this.
CH
Yes, how can we tell Vivado to treat every .vhd file as VHDL 2008, all current project files and all new to be added later. Or even better, for all projects that we might open.
And can I say that having to run or type TCL commands for this is just plain stupid?
But from what I gathered:
Will set all .vhd files currently present in the project to VHDL 2008. But it will not set any new files that I add in the future. So I would need to run this command again every time I introduce new files.
If you dont mind adding a file to the project using tcl:
read_vhdl -vhdl2008 -library <libname> <file_path>
Thanks for giving me a good laugh! Of course I do mind.
