dpaul24
Is the VHDL 'div' operator synthesizable by Vivado2015.4
I want to use the VHDL div operator (/) in my RTL.
It will be something like
loop_value_int <= some_integer_value/32;
loop_value_int and some_integer_value will be declared as signals of type integer having a fixed range.
I have no problem if the result of the division is rounded down.
e.g. 44/32 = 1.375. I am only interested in the value 1, .375 is no use to me.
If the use the above, will I face a problem later during synthesis?
Target dev board is  Artix 701.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
balkris
Yes you can use left **bleep** for division by for other division you can also use divider core
www.xilinx.com/support/documentation/ip_documentation/div_gen_ds530.pdf
/ is vhdl operator for division it should synthesis correctly by tool.
Thanks and Regards
Balkrishan
zdzlin
    If you just need to div a operator with the number of a power of 2, i.e, 2,4,8,16 and so on,you'd
better use the shoft operation instead of the divide, since divide is always the last choice in digital signal
processing
dpaul24
yes, my some_integer_value will always be an integer, such that 2**n = some_integer_value.
I would still like to use the / operator and so question regarding its synth remains the same.
balkris
Thanks and Regards
Balkrishan
dpaul24
Division by 16. It will always remain fixed.
Part 1 =============================================================================
Please confirm if the following RTL will synthesize. I am concerned about the "/" operator.
Can I expect any latency on the signal where / is used?
My pak_clk_i = 125MHz.
 signal frame_length_reg     : std_logic_vector (13 downto 0);
signal pak_len_words        : integer range 0 to 1023;
  process (pak_clk_i)
  begin
    if rising_edge(pak_clk_i) then
      if pak_rst_n_i = '0' then
        pak_len_words <= 0;
      else
        if rx_stats_valid_5q = '1' then
          pak_len_words <= (to_integer(unsigned(frame_length_reg))+12)/16;
        else
          pak_len_words <= pak_len_words;
        end if;
      end if;
    end if;
  end process;
Part 2 =============================================================================
Will I get a performance gain if instead of using "/" operator, I shift data left 4 times, i.e. dividing by 16 or 2^4?
Which one is better to use? Saving clock cycles is my priority!
dpaul
u4223374
Advisor
Advisor
For constant power-of-two division, Vivado will automatically convert "/" into a shift or bit-select operation. Both are effectively free in terms of logic and time.
