Voyager
Voyager
Is there a constraint that allow to specify a resource that I don't want to use?
is there a constraint that allow to specify a resource that I don't want to use? For example don't use a BUFGMUX for a clock signal. Better if XST constraint .Thank you.
Re: Is there a constraint that allow to specify a resource that I don't want to use?
No, there is not a general constraint for you to prohibit any kind of macro inference.
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
@pierlum
There are two ways to control tool behaviour: 1. Use global XST settings. 2. Use attributes for the specific signals.
For example, use of -bufg '0' will make sure that XST generated netlist will not have any global clock buffers. Yes, this may not be an accepted solution of the problem as the other part of the design will need global clock buffers.
Use of attributes should help here, use buffer_type attribute and mentioned the preferred buffer for any particular signal declared in the design.
Anusheel
Helpful answer -> Give Kudos
It depends.
For example, if you don't want XST to automatically insert BUFG for a clock signal, you can add "buffer_type" attribute to this signal.
Similar attributes like ram_style, rom_style, fsm_style, shreg_extract, use_dsp48 and etc.
BTW, XST won't automatically infer BUFGMUX for clock(s). BUFGMUX must be instantiated.
Vivian
Voyager
Voyager
Thank you @viviany and @anusheel for the help! Irrespective of the bufg, it exist a generic specific constrain to avoid the inferring of a specific macro of which I specify the name? Thank you.
Vivian
Voyager
Voyager
Thanks for the help!
Voyager
Voyager
@viviany
I work with ise 14.7 and spartan 6 and XST automatically uses BUFGMUX inferring them as BUFG.
Voyager
Voyager
Sorry for the OT @viviany and @anusheel but someone of you could help me with the very strange problem that I explain here?https://forums.xilinx.com/t5/Implementation/LDCE-and-ILOGIC2-very-strange-problem/td-p/770728
I work with spartan 6 and ise 14.7. Thank you.
@pierlum wrote:
@viviany
BUFGMUX function must be instantiated. It accepts two clock input and does a 2-to-1 selection.
Are you sure you see a BUFGMUX inference?
I guess it is just a BUFG. And BUFG is one of the configurations of BUFGCTRL.
BUFGMUX is another configuration of BUFGCTRL.
They are all based on BUFGCTRL primitive.
Voyager
Voyager
@viviany Sorry I explained wrong. The inferred macro it's a BUFG but from the point of view of the resources used infer BUFGs consume BUFGMUXs
Guide
Guide
The Spartan-6 has only one type of global clock buffer - it is the BUFGMUX. A BUFG doesn't really exist - it is just a BUFGMUX with the S input tied to a constant (and one of the clock inputs ignored).
So the fact that it is using a BUFGMUX when you want a BUFG is correct. You can't (and don't want to) prevent this.
Avrum
