Visitor davidrupe
Is there support for string parameters in SystemVerilog?
 parameter string                 NAME = "UNIQUE_NAME",
[Synth 8-27] string type not supported ["my_file.sv":14]
If not, there should be!
Re: Is there support for string parameters in SystemVerilog?
If you need a work around, you can probably drop the "string" type, and do it classic verilog style:
parameter name = "UNIQUE_NAME";
    or
parameter [11*8:1] = "UNIQUE_NAME";
    or
@davidrupe
There is an existing CR(Change request)#951093 on Vivado synthesis to support SystemVerilog string type parameters.
This will be fixed in future releases of Vivado. Untill then you can use the Workaround of removing the string datatype, a string can still be used and is detected by Synthesis:
 parameter  NAME = "UNIQUE_NAME";
Syed
Visitor davidrupe
Perfect, thanks guys.  I think the problem is I never actually used verilog much.  Straight from VHDL to SystemVerilog.  Didn't even think to remove the type...did think of the byte array though.
What release will this be fixed in? As of 2018.2 it is still not fixed. My issue is the following:
  parameter SZ,
  parameter string X[SZ]
If I leave "string" in there, Quartus and Modelsim are happy but Vivado isn't
If I take it out, Vivado is happy, but Modelsim isn't
Visitor sroche11
Here is a workaround that worked for me, with parameter/localparam of type array of string :
`define _NO_SIM
//pragma translate_off
`undef _NO_SIM
//pragma translate_on
module module_name
`ifdef _NO_SIM
parameter X[3] = '{"A","B","C"},
`else
parameter string X[3] = '{"A","B","C"},
`endif
`ifdef _NO_SIM
localparam XX[3] = '{"AA","BB","CC"};
`else
localparam string XX[3] = '{"AA","BB","CC"};
`endif
It turned out string type will not be supported.
Please use the workarounds mentioned in this thread.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
