Is this situation normal?
I found in the synthesis report a clock was generated for my FSM.Is this situation normal?Thanks!
I use ISE10.1 XST.
My FSM code is as below:
always @(posedge clk or negedge rst)
       if(~rst)  txstate<=IDLE;
       else  txstate<=txstate_next;
always @(*)
    case(txstate)
      IDLE:      if(~rdy0)         txstate_next<=LOADST;
                 else              txstate_next<=IDLE;
      LOADST:    if(loadst_done)   txstate_next<=LOADDATA;
                 else
                 if(loadst_err)    txstate_next<=IDLE;
                 else              txstate_next<=LOADST;
      LOADDATA:  if(loaddata_done) txstate_next<=CRC;
                 else
                 if(loaddata_err)  txstate_next<=IDLE;
                 else              txstate_next<=LOADDATA;
      CRC:       if(crc_done)      txstate_next<=SENDDATA;
                 else              txstate_next<=CRC;
      SENDDATA:  if(timeout)       txstate_next<=IDLE;
                 else
                 if(senddata_done) txstate_next<=PADDING;
                 else              txstate_next<=SENDDATA;
      PADDING:   if(done)          txstate_next<=IDLE;
                 else              txstate_next<=PADDING;
      default:   txstate_next<=IDLE;
      endcase
Re: Is this situation normal?
Not a joke, right?
You mean that the _sequential_ FSM generates a clock or that it needs a clock? The first always block infers your state registers and these seem to require a clock and a negedge reset, pretty conventional stuff that indeed uses a clock.
Cheers!
woutersj :sure,clk is the system clock and it is in the synthesis report.Besides clk,a new clock was generated named  rxstate_FSM_FFd2.
But I didn't use any other signal as a clock in the code.Why?
Historian
Historian
The code snippet you posted makes no mention of a signal called rxstate (which I assume is the state register for the receiver machine).
sorry, a spelling mistake.it should be   txstate_FSM_FFd2
just now I tried again and found the gated clock was generated when the length of the frame is a variable.
when the frame's length is fixed,no gated clock was generated.
why?
Historian
Historian
why?
So you need to tell us the name of this gated clock.
You're only showing us the state-transition part of your state machine, and it's one of those awful two-process machines. There is obviously something else (another always block?) that uses the state register to determine what to do next. And I suspect that this unknown (to us) logic has code that creates the SPI clock by doing something like
    spiclk <=  clk & enable;
and worse, you use spiclk as both the SPI clock output and as an internal FPGA clock.
-a
The remaining part of the code are all something like "always@(posedge clk)  if(txstate == /onestate/)    signal<=value;"
 I didn't use combinational logic to generate a clock and there's no more clock in this code.
The only reason that caused the problem was the variable length of the frame.
Once this was set to be a constant,the gated clock didn't show up again.
The name of the generated gated clock  is  txstate_FSM_FFd2.
Historian
Historian
without seeing the rest of the code it's impossible to determine what's going on.
Oh, and it appears that you have a three-process state machine (one combinatorial process for state transitions, a second process to register the state variable, and a third to update outputs based on the state). I suspect that this is the root of your problem -- sometimes the tools have a difficult time with that third process which decodes the states and updates the machine outputs.
Try re-writing the state machine using the synchronous single-process (always block) style.
thanks, bassman
I'll try the other fsm coding styles but it seems a little difficult to use the one-process style because the output logic is a little complex...
but,,,the three-process style works well and no gated clock is generated at all when I set the frame length to be a constant.
so,,maybe there're other reasons...
Historian
Historian
Like I said, without seeing the code it is not possible to guess.
Historian
Historian
jason_1997 wrote:
thanks, bassman
I don't know -- I've always found that using the one-process state machine makes my life a lot easier, even with complex output logic.
-a
I'll try it.thanks!:)
