Voyager
Voyager
LOC XST constraint with wildcard
I'm currently working on a design with Spartan 6 xc6slx150t-3fgg900, using ISE 14.7 and Verilog language. It is correct to write in a .v a constraint with the wildcard for example ( *LOC = "ILOGIC_X*Y*) or the wildcard can be used only in the .ufc? Thank you.
Guide avrumw
Guide
Re: LOC XST constraint with wildcard
So, yes, it appears to be legal syntax, although I have never seen anyone use it.
Nonetheless, the "correct" way to force a flip-flop into the IOB is using the IOB property I described, not a LOC constraint with a wildcard.
Avrum
Guide avrumw
Guide
No. You cannot do this. It is not even legal in the UCF file; the LOC location must be a string with no wildcards.
If you want to force a flip-flop into the IOB (which is what the ILOGIC is), set the IOB=TRUE (or IOB=FORCE) property on the flip-flop. This CAN be done in the RTL.
(* IOB = "FORCE") reg my_iob_ff;
always @(posedge clk)
begin
  my_iob_ff <= (whatever);
end
This will force the flip-flop my_iob_ff into the IOB.
Avrum
Voyager
Voyager
@avrumw,
thank you for the reply. Looking at https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/cgd.pdf pg 124 it seem that using wildcards in LOCATION constraints in the .ucf file it is legal. What do you think? Thank you.
Guide avrumw
Guide
Avrum
Voyager
Voyager
Thank you for the reply. I used the LOC constraint with wildcard because I wanted to force FFs and latches specifically in ILOGIC blocks. Thanks for the help!
