nikolay
LUT_MAP constraint for XST
I have problem with the synthesis constraint LUT_MAP for XST (ISE 10.1)
I want to force XST to map a combinatorial function that has 5 inputs and 2 outputs on a single LUT6_2 in Virtex5. I tried to do this by using VHDL attributes (as described in the XST User Guide)  in the following way:
entity myFUNC is
    port (
        -- 5 x In
        I0 : in  STD_LOGIC;
        I1 : in  STD_LOGIC;
        I3 : in  STD_LOGIC;
        I4 : in  STD_LOGIC;
        I5 : in  STD_LOGIC;
        -- 2 x Out
        G   : out STD_LOGIC;
        CXO : out STD_LOGIC
    attribute LUT_MAP: string;
    attribute LUT_MAP of myFUNC : entity is "yes";
end myFUNC ;
However, XST does not respond,and does not give any explanation for that. The best result I can get is 2 times LUT5.
I tried using synthesis constraint file (according to the XST User Guide):
MODEL "myFUNC" lut_map=yes;
The result was the same - XST does not respond to the constraint.
The third way I can try is to instantiate directly a LUT6_2 primitive, but I would like to avoid this, if possible.
Does anybody knows what could be the reason that XST does not obey the LUT_MAP constraint?
blaine
You should use the HLUTNM constraint. This will add a hierarchy name and allow you to reuse it more than once in a design.
John
gszakacs
Professor
Professor
I don't see the LUT_MAP constraint in the ISE 10.1 constraint guide.  Don't you want to
use the "LUTNM" constraint?
-- Gabor
nikolay
Hi ,
The LUT_MAP constraint I found here : http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/xst.pdf , page 338. It is a synthesis constraint, not a MAP or PAR constraint.
Anyway, thanks for your suggestion. The LUTNM seams to be another option I didn't know about. However, it will require more effort - I have to identify all the pairs of LUT5 (they are many) and assign the same LUTNM name to each pair.
blaine
John
