11-05-2013 12:15 AM
I recently started on a new design using VHDL. VHDL is a long time ago for me, so now I really don´t now why this is happening, I tried a lot of thing to solve, but probably I´m just missing something simple.
I have two state machines for reading a sensor and compensating it with a value. For this I made two frame buffers for reading and two frame buffers for compensating. This is most of my source:
architecture Behavioral of top is ------------------------------------- -- Camera sensor state types: -- sIdle: Sensor wacht op actie. [ gaat naar: sIdle, sInit, sRead ] -- sInit: Initialiseren/instellen van sensor [ gaat naar: sInit, sIdle ] -- sRead: Leest huidige waarde van sensor op rising edge van de pxl clock [ gaat naar: sRead, sGoNext ] -- sGoNext: Verhoogt de huidige pixel counter en checkt of er nog nieuwe pixels komen binnen het frame [ gaat naar sRead, sFinish ] type tSensorState is (sIdle,sInit,sRead,sGoNext); ------------------------------------- -- Compensatie state types: -- sIdle: Compensatie proces wacht op actie [ gaat naar sIdle, sComp ] -- sComp: Compenseert pixel: Compenseert de huidige pixel [ gaat naar sGoNext ] -- sGoNext: Verhoogt de huidige pixel counte ren checkt of er nog nieuwe pixels komen binne het frame [ gaat naar sComp, sFinish ] type tCompState is (sIdle, sComp, sGoNext); -- Camera state machine signals signal currentSensorState, nextSensorState: tSensorState := sIdle; -- Compensate state machine signals signal currentCompState, nextCompState: tCompState := sIdle; -- frame ready signals signal readFrameReady: STD_LOGIC := '0'; signal compFrameReady: STD_LOGIC := '0'; -- buffers voor frames. elk type zijn 2 buffers van 2048 10 bit getallen type tFrameBuffer is array(1 downto 0, 2047 downto 0) of integer range 0 to 1023; -- compensatie frame type 2048 10bit getallen type tCompFrame is array(2047 downto 0) of integer range 0 to 1023; -- Lees buffers shared variable readFrameBuffer : tFrameBuffer := (OTHERS => (OTHERS=>0)); -- Compensatie buffer shared variable compFrameBuffer : tFrameBuffer := (OTHERS => (OTHERS=>0)); -- Compensatie frame shared variable compFrame : tCompFrame := (OTHERS=>0); -- Frame buffer teller shared variable atFrameBuffer : integer range 0 to 1 := 0; -- Lees pixel teller shared variable readAtPixel : integer range 0 to 2047 := 0; shared variable compAtPixel : integer range 0 to 2047 := 0; begin ------------------------------------ -- State machine schakelaar clkProcess: process (CLKin) begin if (rising_edge(CLKin)) then currentSensorState <= nextSensorState; currentCompState <= nextCompState; end if; end process clkProcess; ------------------------------------ -- Sensor state machine process(currentSensorState, DLISKpclk, DLISKfvalid) begin case currentSensorState is when sIdle => readFrameReady <= '0'; readAtPixel := 0; if (DLISKfvalid = '1') then nextSensorState <= sRead; else nextSensorState <= sIdle; end if; when sInit => nextSensorState <= sIdle; when sRead => if (rising_edge(DLISKpclk)) then readFrameBuffer(atFrameBuffer,readAtPixel) := to_integer(unsigned(DLISKdata)); nextSensorState <= sGoNext; else readFrameBuffer(atFrameBuffer,readAtPixel) := 0; nextSensorState <= sRead; end if; when sGoNext => if (readAtPixel = 2047) then readAtPixel := 0; readFrameReady <= '1'; nextSensorState <= sIdle; if (atFrameBuffer = 0) then atFrameBuffer := 1; else atFrameBuffer := 0; end if; else readAtPixel := readAtPixel + 1; nextSensorState <= sRead; end if; end case; end process; ----------------------------- -- Compensatie state machine compensateProcess: process (currentCompState, readFrameReady) begin case currentCompState is when sIdle => if (readFrameReady = '1') then nextCompState <= sComp; else nextCompState <= sIdle; end if; when sComp => compFrameBuffer(atFrameBuffer,compAtPixel) := readFrameBuffer(atFrameBuffer+1,compAtPixel) * compFrame(compAtPixel); nextCompState <= sGoNext; when sGoNext => if (compAtPixel = 2047) then compAtPixel := 0; if (compFrameBuffer(atFrameBuffer,readAtPixel) = 100) then DLISKsenb <= '1'; else DLISKsenb <= '0'; end if; nextCompState <= sIdle; else compAtPixel := compAtPixel + 1; nextCompState <= sComp; end if; when others => nextCompState <= sIdle; end case; end process compensateProcess; end Behavioral;
And this source gives me 90000+ warnings because of latches like:
WARNING:Xst:2999 - Signal 'compFrame', unconnected in block 'top', is tied to its initial value. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameReady>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<10>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<9>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<8>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<7>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<6>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<5>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<4>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<3>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<2>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<1>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readAtPixel<0>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><2047><9>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><2047><8>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><2047><7>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><2047><6>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><2047><5>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><2047><4>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><2047><3>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><2047><2>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><2047><1>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. ....... WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><0><2>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><0><1>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<1><0><0>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<0><2047><9>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<0><2047><8>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<0><2047><7>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. WARNING:Xst:737 - Found 1-bit latch for signal <readFrameBuffer<0><2047><6>>. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems. ....
11-05-2013 12:27 AM
11-05-2013 12:45 AM
Hmmm.. Thanks for the answer so far.
I was also just looking at my source and I don't really know why I'm using an extra process for compensating at all. I'll try to make an improved source.
11-05-2013 03:17 AM
11-05-2013 03:24 AM
Why not?
I simplified my software now a lot and there are no latches anymore
-- State machine schakelaar clkProcess: process (CLKin) begin if (rising_edge(CLKin)) then currentSensorState <= nextSensorState; end if; end process clkProcess; ------------------------------------ -- Sensor state machine process(currentSensorState, DLISKpclk, DLISKfvalid) begin case currentSensorState is when sIdle => readAtPixel := 0; if (DLISKfvalid = '1') then nextSensorState <= sRead; else nextSensorState <= sIdle; end if; when sRead => if (rising_edge(DLISKpclk)) then FrameBuffer(readAtPixel) := to_integer(unsigned(DLISKdata(9 downto 0))) * compFrame(readAtPixel); if (readAtPixel = 2047) then nextSensorState <= sIdle; else readAtPixel := readAtPixel + 1; nextSensorState <= sRead; end if; -- do something with the output if (FrameBuffer(readAtPixel) = 100) then DLISKsenb <= '1'; else DLISKsenb <= '0'; end if; ------ end if; end case; end process;
But also use it here. Still have a warning:
Xst:3002 - This design contains one or more registers/latches that are directly
incompatible with the Spartan6 architecture. The two primary causes of this is
either a register or latch described with both an asynchronous set and
asynchronous reset, or a register or latch described with an asynchronous
set or reset which however has an initialization value of the opposite
polarity (i.e. asynchronous reset with an initialization value of 1).
Is this because of that? And how should I fix it? Want it to happen once and only in that state.
11-05-2013 07:27 AM
11-05-2013 11:19 AM
Definitely re-write the state machine to use one synchronous process. Two-process state machines are a FAIL. Your latches are the result of not assigning to all left-hand-side signals in ALL states in a combinatorial process.
Plus the rising_edge(DLISKpclk) doesn't do what you expect. If you want an edge detector, you need to code a delay flop and compare it with the current signal value.
Finally: Why are you using shared variables?
11-06-2013 04:56 AM
Oke added the changes and simplified is even more:
- only one process for the state machine
- created a rising edge flipflop for the pxlClk
- shared variables was because of multiple process. Now they are in the proces.
- added a reset (but want to remove this one in the future)
type tSensorState is (sIdle,sRead); -- buffers voor frames. elk type zijn 2 buffers van 2048 10 bit getallen --type tFrameBuffer is array(1 downto 0, 2047 downto 0) of integer range 0 to 1023; type tFrameBuffer is array(2100 downto 0) of integer range 0 to 1023; -- Camera state machine signals signal currentSensorState, nextSensorState: tSensorState := sIdle; -- frame ready signals signal readFrameReady: STD_LOGIC := '0'; signal risingEdgePxlCLK: STD_LOGIC := '0'; begin ------------------------------------ -- State machine schakelaar clkProcess: process (CLKin,reset) variable resync : std_logic_vector(0 to 1); begin if (reset = '1') then currentSensorState <= sIdle; risingEdgePxlCLK <= '0'; resync := "00"; elsif (rising_edge(CLKin)) then currentSensorState <= nextSensorState; resync(1) := resync (0); resync(0) := DLISKpclk; risingEdgePxlCLK <= resync(0) and not resync(1); end if; end process clkProcess; ------------------------------------ -- Sensor state machine process(currentSensorState, risingEdgePxlCLK, DLISKfvalid, DLISKdata) variable FrameBuffer : tFrameBuffer := (OTHERS=>0); variable readAtPixel : integer range 0 to 2100 := 0; begin case currentSensorState is when sIdle => readAtPixel := 0; FrameBuffer := (OTHERS=>0); if (DLISKfvalid = '1') then nextSensorState <= sRead; else nextSensorState <= sIdle; end if; when sRead => if (risingEdgePxlCLK = '1') then FrameBuffer(readAtPixel) := to_integer(unsigned(DLISKdata(9 downto 0)));-- * compFrame(readAtPixel); if (readAtPixel = 2100 or DLISKfvalid = '0') then readAtPixel := readAtPixel; nextSensorState <= sIdle; else readAtPixel := readAtPixel + 1; nextSensorState <= sRead; end if; end if; end case; end process;
This works in the simulator.
Synthesize also works, but that is normal. There is no output so the RTL block is empty.
Any comments on this so far?
11-06-2013 06:55 AM
11-06-2013 04:16 PM
Nope, still two processes. You're still decoding the states and determining the next state in a combinatorial process and setting the state register in a synchronous process. Put everything in the synchronous process.
Why are you using variables in the process? Use signals.
Synchronous resets are your friend.
11-08-2013 06:39 AM
Oke thanks for all tips guys!
architecture Behavioral of top is ------------------------------------- -- Camera sensor state types: -- sIdle: Sensor wacht op actie. [ gaat naar: sIdle, sInit, sRead ] -- sInit: Initialiseren/instellen van sensor [ gaat naar: sInit, sIdle ] -- sRead: Leest huidige waarde van sensor op rising edge van de pxl clock [ gaat naar: sRead, sGoNext ] -- sGoNext: Verhoogt de huidige pixel counter en checkt of er nog nieuwe pixels komen binnen het frame [ gaat naar sRead, sFinish ] type tSensorState is (sIdle,sRead); -- buffers voor frames. elk type zijn 2 buffers van 2048 10 bit getallen --type tFrameBuffer is array(1 downto 0, 2047 downto 0) of integer range 0 to 1023; type tFrameBuffer is array(2100 downto 0) of integer range 0 to 1023; signal FrameBuffer : tFrameBuffer := (OTHERS=>0); signal readAtPixel : integer range 0 to 2100 := 0; -- Camera state machine signals signal SensorState: tSensorState := sIdle; -- frame ready signals signal readFrameReady: STD_LOGIC := '0'; signal risingEdgePxlCLK: STD_LOGIC := '0'; signal risingEdgeCountWheel: STD_LOGIC := '0'; signal clk250MHz: STD_LOGIC; signal clk50MHz: STD_LOGIC; component clockDiv is port (-- Clock in ports CLK_IN : in std_logic; -- Clock out ports CLK_250 : out std_logic; CLK_50 : out std_logic ); end component; begin clknetwork : clockDiv port map (-- Clock in ports CLK_IN => CLKin, -- Clock out ports CLK_250 => clk250MHz, CLK_50 => clk50MHz ); DLISKmclk <= clk50MHz; ------------------------------------ -- State machine switcher clkProcess: process (clk250MHz,reset) variable pixelMask : std_logic_vector(0 to 1); variable countWheelMask : std_logic_vector(0 to 1); variable delayCounter : integer range 10 downto 0; begin if (reset = '0') then risingEdgePxlCLK <= '0'; risingEdgeCountWheel <= '0'; pixelMask := "00"; countWheelMask := "00"; delayCounter := 0; elsif (rising_edge(clk250MHz)) then pixelMask(1) := pixelMask (0); pixelMask(0) := DLISKpclk; countWheelMask(1) := countWheelMask (0); countWheelMask(0) := Telwiel; risingEdgePxlCLK <= pixelMask(0) and not pixelMask(1); if (countWheelMask(0) = '1' and countWheelMask(1) = '0') then delayCounter := 5; end if; if (delayCounter > 0) then delayCounter := delayCounter - 1; risingEdgeCountWheel <= '1'; else delayCounter := 0; risingEdgeCountWheel <= '0'; end if; end if; end process clkProcess; ------------------------------------ -- Sensor state machine stateMachine: process(clk250MHz,reset,SensorState, risingEdgePxlCLK, DLISKfvalid, DLISKdata) begin if (reset='0') THEN SensorState <= sIdle; DLISKstart <= '0'; DLISKsenb <= '0'; elsif (rising_edge(clk250MHz)) THEN case SensorState is when sIdle => readAtPixel <= 0; FrameBuffer <= (OTHERS=>0); if (risingEdgeCountWheel = '1') then DLISKstart <= '1'; else DLISKstart <= '0'; end if; if (DLISKfvalid = '1') then SensorState <= sRead; else SensorState <= SensorState; end if; when sRead => if (risingEdgePxlCLK = '1') then FrameBuffer(readAtPixel) <= to_integer(unsigned(DLISKdata(9 downto 0)));-- * compFrame(readAtPixel); if (FrameBuffer(readAtPixel) = 200) then DLISKsenb <= '1'; else DLISKsenb <= '0'; end if; if (readAtPixel = 2100 or DLISKfvalid = '0') then readAtPixel <= readAtPixel; SensorState <= sIdle; else readAtPixel <= readAtPixel + 1; SensorState <= SensorState; end if; end if; end case; end if; end process stateMachine; end Behavioral;
1 process state machine.
Names for processes
Delays for some signals.
No more latches and simulation is also working as supposed so far!
But, of course: Xst:1336 - (*) More than 100% of Device resources are used
Comments are still welcome!
Now going to find out how to use the Block Ram memory.
11-08-2013 07:13 AM
11-08-2013 11:02 AM
Here's why:
That's 2.15 megabits. I'm not sure what device you're targeting. You do need one of the very large FPGAs. And my guess is you're not getting a proper RAM inference, hence the usage blows up. The tools can be kinda dumb, so it might be easiest to separate out the BRAM inference from the state machine.
11-11-2013 12:05 AM
Bassman:
You mean 2,6kB?! 2101 * 10 bit = 21010 bit / 8 is about 2,6 kB. This is not that much?!
I will also make it of a single sync and async process.
11-12-2013 12:59 AM
11-12-2013 09:24 AM
@mobics wrote:
Bassman:
Whoops, sorry, you're right.
