Voyager
Voyager
Limitations of Unpacked Arrays in Systemverilog
Systemverilog has 2 array types: "packed" and "unpacked".
As far as I understand - unpacked arrays can accept types that packed arrays cannot.
So why not  make a rule and elusively use unpacked arrays in the design ?
What limitations do unpacked arrays have ?
Re: Limitations of Unpacked Arrays in Systemverilog
SystemVerilog packed array are powerful tools.  In fact we do the opposite to your suggestion and almost exclusively use packed arrays instead of unpacked.
Packed arrays, (and structures, and unions) can be used with more operators than unpacked types.  They are Integral types according to the standard - thus many more operations can be done with them - see Table 11-1 "Operators and data types" from the 1800-2012 standard. i.e all arithmetic operators are valid on packed types. Not with unpacked.
Mark
Mark
Voyager
Voyager
1.Can you please provide a document to the link you're referring to ?
2.I come from VHDL background and most of my interest is in synthesizable Systemverilog - when would it be wiser to use unpacked arrays in synthesis ?
I'm referring to the IEEE 1800 SystemVerilog Standard.  If you're an IEEE member, I believe you can download it for free.  Ask your favorite search engine.  Highly recommended for any person using SystemVerilog in any form.
Early on, synthesizer vendors suggested that unpacked arrays could be implemented more efficiently. I'm doubtful that this is the case - at least in general - for modern synthesis tools.  Like I said, our whole team almost exclusively uses (multi-dimensional) packed arrays - in synthesizable code.  Unpacked array is the exception not the rule for us.  A VHDL user may prefer unpacked arrays, because it's more strongly typed, similar to VHDL - emitting compile time errors when array dimensions don't exactly match.  But verilog users have always been fast and loose with assignment, relying on verilog's built-in extension, and truncation rules.  Whether or not you think that's a good thing is up to you.  For us, the ability to treat a packed array as an integral type outweighs any drawbacks.
Mark
