Voyager
Voyager
Line buffer with register sets : Will Vivado tool convert to Block RAM ?
Here is the code which I would like to implement
   type t_ramType is array (0 to 2**g_AddrWidth-1) of std_logic_vector(g_DataWidth-1 downto 0);
   shared variable ram : t_ramType := (others => (others => '0'));
   signal readB : std_logic_vector(8*g_DataWidth-1 downto 0);
begin
   process (CLK_in)
      variable BVec : std_logic_vector(g_AddrWidth-1 downto 0);
   begin
      if rising_edge(CLK_in ) then
         if (Enab_in  = '1') then
            BVec := Addr_in ;
            for ii in 0 to 7 loop
               BVec(2 downto 0) := std_logic_vector(to_unsigned(ii, 3));
               readB((ii+1)*g_DataWidth-1 downto ii*g_DataWidth) <= ram(to_integer(unsigned(BVec)));
            end loop;
            ram(to_integer(unsigned(Addr_in ))) := Data_in ;
         end if;
         if (Force_in = '1') then
            Data_out  <= (others => '0');
         else
            Data_out  <= readB;
         end if;
      end if;
   end process;
end behavioral;
Here it can been seen that huge register set is assigned as matrix and the tool after synthesizing it convert it to block RAM. As the reading the memory location is done in a  for loop , 8 location are read in one cycle.
My question is in zynq ultrascale +, how it get converted or can be implemented ? I would like to use UltraRAM and BlockRAM combination, how can I do that ?
Kind regards
Teacher xilinxacct
Re: Line buffer with register sets : Will Vivado tool convert to Block RAM ?
@msh
You may want to explicitly use the block memory generator from the IP catalog.
Scholar drjohnsmith
Have you tried the templates option, xilinx provide various templates that you just paste in and you get the blocks
try page 3 here as a way forward https://www.xilinx.com/support/documentation/white_papers/wp477-ultraram.pdf
