volta
Location constraints, strings and Verilog
Hi!
I’ve write a VHDL code using the location constraints and the generate statement and now I want to translate the same code to Verilog.
The VHDL code looks like this:
                attribute LOC of INV1:label is "X" & integer'image(i)& "Y" & integer'image(j);
Unfortunately when using Verilog, the concatenation operator { , } and the string data type don´t work the same as VHDL. For example
                This sentence works:                    (* LOC = "SLICE_X25Y63" *)
                This sentence doesn´t work:     (* LOC = {"SLICE_X25Y","63"} *)
In theory the string "SLICE_X25Y63" should be exactly the same as {"SLICE_X25Y","63"} but the LOC constraint can only work with the first one.
Is there any way to successfully translate my VHDL sentence to Verilog?
allanherriman
Mentor
Mentor
I recall having a similar discussion back in 2003.
muzaffer
@volta unfortunately Xilinx doesn't do constant manipulation properly with Verilog so this is not doable. They have closed a SR I opened with "won't fix".
