Making and using own IP on ISE
Hello all,
I am a newbie in Xilinx's ISE. I am wondering, how can I make my own IP core? Also how can I implement a certain IP into my codes for example the binary counter? Can you please give me the link to the proper manuals, due to the fact that I find only for Vivado!
Thank you in advanced
P.S. I am "playing" with Spartan 6 XC6SLX9
Re: Making and using own IP on ISE
Hi @bibishte
You can achieve the functionality with ISE free license. Here are the steps:
1. Create a project with your code in ISE
2. Run synthesis and generate .ngc file
3. Share this .ngc file with others and provide instantiation template to instantiate this .ngc netlist in their project.
Vinay
Hello @bibishte,
Please check this thread
https://forums.xilinx.com/t5/Implementation/custom-IP-core-creation-in-ISE/td-p/691502
To know more about core generator, you can refer below links -
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/cgn_p_create_custom_core.htm
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/cgn_p_add_ip_projnav_design.htm
Ashish
Hello @ashishd,
Let's check if i am understanding this!
So to make my own IP for ISE I have to acquire an Alliance member license for it, right? In this case scenario is there a way of setting and making my own IP that the others can use, but not manpulate the code inside of it?
Thank you
Hi @bibishte
Yes, in that case you can share your IP with others but they cant manipulate the code.
Vinay
Hello @vuppala,
Is there a way with the free license for ISE to create an entity which i can share without the option for the user of changing it? And if the answer is "yes" how? Please send me a link to the manual!
Thank you!
Hi @bibishte
Vinay
Thank you a lot team! Marking the thread as resoved! :)
