techway
Multiple Assignment codign rule
Hi all,
I have a very simple question concerning what is allowed or not in a VHDL process.
Up to, is it allowed to write this (for synthesis)?
my_proc: process(CLK)
    begin
      if rising_edge(CLK) then
          foo <= '0'
          if bar='1' then
            foo <= '1';
          end if;
      end if;
    end process;
Same Question with :
    begin
          if bar_0='1' then
            foo <= '1';
          end if;
          if bar_1='1' then
            foo <= '0';
          end if;
      end if;
    end process;
Tx
anusheel
@techway
          foo <= '0'
          if bar='1' then
            foo <= '1';
          end if;
Above statement is as good as bar directly connected to 'D'  pin of flop.
          if bar_0='1' then
            foo <= '1';
          end if;
          if bar_1='1' then
            foo <= '0';
          end if;
Suppose bar_0 and bar_1 both are '1' then the assignment after bar_1 condition will be updated (foo <= '0').
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
anusheel
@techway
Yes, you can use multiple if statements.
   if <condition> then -- RST = '1'
      <statement>
    end if;
Anusheel
techway
In fact the question was focused on the fact that foo is concurrently assigned with different values in the same process depending on which condition is true.
anusheel
@techway
          foo <= '0'
          if bar='1' then
            foo <= '1';
          end if;
          if bar_0='1' then
            foo <= '1';
          end if;
          if bar_1='1' then
            foo <= '0';
          end if;
Anusheel
evanslatyer
The synthesis tool can handle multiple assignment within one block of code, in VHDL or Verilog. This is because within one block it has a simple rule to follow: the last assignment always wins. Following this rule ensures that the final value is unambiguous.
The problems occur when you assign values to one variable from different blocks. There is no rule that says which block gets executed first; in hardware they're  simultaneous, and the simulator uses whatever order it feels like. As a result, the synthesis tool cannot determine who gets to write.
techway
thank you for your detailed answer@evanslatyer
