Visitor dreaguns
Multiple Drivers Issue
I can't seem to fix this "multiple driver" error.
It seems "const0" is driven by BUFR_inst/O, dac/MOSI_reg/Q & GND so perhaps if I remove the ground, then it would go away but its a read-only vhd file in system.bd
Re: Multiple Drivers Issue
The collision could be that signal exp_2 is an output and your DAC_Handler wants to output to the same port.
Is this issue fixed, were you able to proceed. At first instance this looks false message.
If not , you could debug why dac/MOSI_reg D pin is connected to GND. Does it have dont_touch or keep applied on output of flop or flop itself.
Also, is it possible to share design for someone in factory to take a look.
Show us the source, not the synthesized. That only reflects the error. And the error is to be fixed in vhdl/verilog
Visitor dreaguns
It was this contention. Thanks for your input.
'multiple drivers' are usually easy.  What is confusing is the error message that points you somewhere else. Seen that many times, not surprised.
