Observer bahadirozk
Multiple declarations of "=" included via multiple use clauses; none are made directly visible
Error : Multiple declarations of "=" included via multiple use clauses; none are made directly visible
help me please
Re: Multiple declarations of "=" included via multiple use clauses; none are made directly visible
Hi @bahadirozk ,
Because of using use ieee.std_logic_unsigned.all and  use ieee.std_logic_signed.all packages together the issue is coming.
May be there is declaration of some variable or constant in both packages, due to which you are facing this issue, removing any one of the package will resolve the error. Also check this AR link for reference:
https://www.xilinx.com/support/answers/32983.html
Raj
Hi @bahadirozk ,
Raj
Scholar richardhead
You also included std_logic_arith and numeric_std, which both declare signed/unsigned and arithmatic. You should also delete std_logic_arith.
Note: std_logic_unsigned, std_logic_signed and std_logic_arith are all non-standard VHDL packages. Their use is discouraged.
Observer bahadirozk
thanks your solving. The solution works.
Hi @bahadirozk ,
Do you have further queries on this? If not, please close this thread by marking it as accepted solution.
Raj
