huangpoh
Multiplier using numeric (VHDL)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity MULTIPLIER is
    Port ( A : in  STD_LOGIC_VECTOR (7 downto 0);
           B : in  STD_LOGIC_VECTOR (3 downto 0);
           RES : out  STD_LOGIC_VECTOR (11 downto 0));
end MULTIPLIER;
architecture Behavioral of MULTIPLIER is
	signal A_int: integer;
	signal B_int: integer;
	signal RES_int: integer;
begin
	A_int <= to_integer(unsigned(A));
        B_int <= to_integer(unsigned(B));
	RES_int <=  A_int * B_int;
        RES <= std_logic_vector(to_unsigned(RES_int , RES'length) );
--if I comment out everything related with RES_int and use the below code everything works --RES <= std_logic_vector(to_unsigned(A_int * B_int , RES'length) ); end Behavioral;
with the above code I get, but I don't understand why? Can someone help me understand?
Xst:646 - Signal <RES_int<31:12>> is assigned but never used. This unconnected signal will be trimmed during the optimization process.
Thanks in advance.
vijayak
Hi @huangpoh
Your output is just 12 bit and you are assigning it to 32 bit values. So the the remaining bits 31:12 are never used.
I believe you are seeing the expected output in the simulation. Do you?
Thanks,Vijay
vijayak
Hi @huangpoh
Thanks,Vijay
