gszakacs
Professor
Professor
Multisource errors in some Verilog processes with more than one assignment in the same block
The following code illustrates the problem in XST10.1.03
Although full_histo_addr is only assigned in one always block it shows up as a multisource
with one connection to GND if I uncomment the code near the top.  The final else clause
was added to work around the error.  As noted below the similar but simpler code for
full_histo_clear did not cause a similar error.
always @ (posedge clk_in or posedge rst_in)
begin : LaneBlock
  integer i;  // local loop variable
  if (rst_in)
    begin
      full_histo_raddr <= 0;
      full_histo_clear <= 0;
    end
  else
    begin
      // Default to zero for cases not covered below
      // The following line created a "multi-source" error in XST
      // This is a bug.  Interestingly the line
      // after this does not produce the same error.
//      full_histo_raddr <= 0;
//      full_histo_clear <= 0;
      for (i = 0;i < 10;i = i + 1)
        begin
          if (cl1_lanes[i])
            begin
              full_histo_clear[i] <= cl1_clear;
              full_histo_raddr[i*8 +: 8] <= cl1_raddr;
            end
          else if (cl2_lanes[i])
            begin
              full_histo_clear[i] <= cl2_clear;
              full_histo_raddr[i*8 +: 8] <= cl2_raddr;
            end
          else if (cl3_lanes[i])
            begin
              full_histo_clear[i] <= cl3_clear;
              full_histo_raddr[i*8 +: 8] <= cl3_raddr;
            end
        // Originally there was no "else" clause and I expected
        // this to be covered by the pre-assignments above.  That
        // caused "multi-source" errors as noted above.
          else
            begin
              full_histo_clear[i] <= 0;
              full_histo_raddr[i*8 +: 8] <= 0;
            end
        end
    end
end
This thread shows another example of the same problem, this time in a combinatorial
always @* block:
http://forums.xilinx.com/xlnx/board/message?board.id=Spartan&thread.id=3808
I've found a workaround for these cases, but it is something to look for when getting
multi-source errors in XST.
-- Gabor
