mat075
My clk input is still 100MHz (gclk)
Hello everybody !
First of all, I'm a beginner in FPGA so please be nice with me :) !
My problem is very simple but I tried a lot of things to solve it but I still can't manage it. I use an Artix - 7. I want to modify the internal clock (GCLK pin E3 bank 35 100MHz). I launched synthesis Design, after I edited "edit timing contraints" to modify the clock at 50Khz.. To verify if it's good, I launched " Constraints Wizard " and  "Report clock Network "everything is ok. But after program my device ( thanks to .bit file) I still have 100MHz in my clk ouput (the clk input is directly connect to this ouput to see on the scpoe the signal) whereas I want 50Khz.. I checked my xdc File and the frequency is 50KHz. No erros in  log file.
What can I do ?
(Sorry for my bad English )
florentw
Hi @mat075,
A constraint is only to inform vivado about what you have. So if you just create a constraint for 50KHz, the tool will just think you have a 50KHz clock while in fact you still have a 100MHz clock (this is what you see).
To really create a new clock you would need to use an MMCM or a PLL. The easy way for this is to use a clocking wizard IP.
But you won't be able to go as low as 50kHz so you wil have to do a clock divider in vhdl or verilog.
Kind Regards,
Florent
Florent
florentw
Hi @mat075,
Kind Regards,
Florent
Florent
mat075
Hi @florentw !
Thanks for your help. Do you have some documents or links to inform me about "cloking wizard IP" ?
reshmaakhil
hi @mat075,
you can use a clock divider.
it will work.
regards,
reshma
yenigal
check below links
https://www.xilinx.com/support/documentation/ip_documentation/clk_wiz/v5_4/pg065-clk-wiz.pdf
https://www.xilinx.com/products/intellectual-property/clocking_wizard.html
Satish
Satish
mat075
What do you mean ?
florentw
Hi @mat075,
The min clock you will be able to output with the clocking wizard on Artix-7 is a clock 4.69MHz (it comes from the limit on the MMCM).
To get a 50kHz you will have to divide the clock by ~100.
The simplest way to do it is to do a clock divider in RTL (VHDL/Verilog) with a counter. Something like (in VHDL):
cnt_sig : std_logic_vector(6 downto 0) := (others => '0');
clk_out : std_logic;
process(clk)
begin
   if(rising_edge(clk)) then
      cnt_sig <= cnt_sig + '1';
      if(cnt_sig = "1100100") then -- if = 100
           clk_out <= '1';
      else
           clk_out <= '0';
      end if;
   end if;
end process;
Then when you will have more experience, the best way is to use a BUFGCE:
But again this will be future improvements when you will have more experience in FPGA.
Kind Regards,
Florent
Florent
mat075
That's very clear now !
Thank you very much guys.
