kidrahiterpu
NaN in VHDL
In my VHDL code i want to compare a value with NaN and then proceed with further operations.
For example
if (x is not NaN) then
How I can do this such that the code is synthesizable?
richardhead
You Dont show what types are being used. Real type is not synthesisable. Float types from float_pkg will not produce optimal logic.  You should be using xilinx float ip cores. But why are you using float at all? Fpgas are not architected for float, they work best with fixed point.
kidrahiterpu
I am working with fixed point data.
richardhead
Fixed point has no representation of NaN. If you are trying to catch a divide by 0, you will have to track that yourself.
apetley
Hi @kidrahiterpu ,
Further, Vivado flags Critical Warning if divide by zero scenario is encountered.
CRITICAL WARNING: [Synth 8-5821] Potential divide by zero in module top
Ajay
