Sunks
Need help with errors in traffic light controller- VHDL
I am getting the following errors. I'm using a Spartan 6 family. Please help on how to proceed
WARNING:HDLCompiler:1127 - "xxxxxxx" Line 82: Assignment to lighta ignored, since the identifier is never used
WARNING:HDLCompiler:1127 - "xxxxxxx" Line 86: Assignment to lightb ignored, since the identifier is never used
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity traffic_light is
    Port ( clk : in  STD_LOGIC;
           Sa : in  STD_LOGIC;
           Sb : in  STD_LOGIC;
           Ra : inout  STD_LOGIC;
           Ya : inout  STD_LOGIC;
           Ga : inout  STD_LOGIC;
           Rb : inout  STD_LOGIC;
           Yb : inout  STD_LOGIC;
           Gb : inout  STD_LOGIC);
end traffic_light;
architecture Behavioral of traffic_light is
signal state, nextstate: integer range 0 to 12;
type light is (R, Y, G);
signal lightA, lightB: light;
begin
	process(state, Sa, Sb)
	begin
	Ra <= '0'; Ya <= '0'; Ga <= '0'; Rb <= '0'; Yb <= '0'; Gb <= '0';
	nextstate <= 0;
		case state is
			when 0 to 4 =>
				Ga <= '1'; Rb <= '1';
				nextstate <= state + 1;
			when 5 =>
				if(Sb = '1') then nextstate <= 6;
				else nextstate <= state; end if;
			when 6 =>
				Ya <= '1'; Rb <= '0';
				nextstate <= 7;
			when 7 to 10 =>
				Ra <= '1'; Gb <= '1'; nextstate <= state + 1;
			when 11 =>
				if (Sa = '1' or Sb = '0') then nextstate <= 12;
				elsif (Sa = '0' and Sb = '1') then nextstate <= state; end if;
			when 12 =>
				Ra <= '1'; Yb <= '1';
		end case;
	end process;
	process(clk)
	begin
		if clk'event and clk = '1' then
			state <= nextstate;
		end if;
	end process;
	lightA <= R when Ra = '1' else
				 Y when Ya = '1' else
				 G when Ga = '1';
	lightB <= R when Rb = '1' else
				 Y when Yb = '1' else
				 G when Gb = '1';
end Behavioral;
baltintop
Voyager
Voyager
Hi @Sunks
The error messages are clear. lightA and lightB are not ports, they are internal signals; however, they are not used anywhere inside your entity (they are not on the right side of an assignment).
richardhead
Also note these are warnings, not errors.
