trupti.chavan
Not able to synthesize code in Verilog 2001 - IEEE Std 1364-2001
I am trying to sithesize below code in vivado 2018.2. Please find the attached code with filenames.
file: param.v
parameter LENGTH = 8,
parameter LSB =1
file: main_cnt.v
module main_cnt #(
       `include "param.v",
        parameter FIFO = 1 ) (
input clk,
input resetn,
... different IO );
<  module_logic  >
endmodule
I am trying to define parameters in a file and include parameter file by `include command. In ideal case, its expected to work, as `include will replace all content of included file at called location.
same code is getting synthesized on synopsis DC. But Vivado is throwing errors for me. How should I synthesize above code in vivado 2018.2.
aschule
What is the exact error that you are getting?  Also, how did you set up your project to run?  I made a quick testcase that looks like yours, and this worked fine for me.  My guess is that there might be something in how this was set up.
trupti.chavan
Please find attached .v files. Also attached project.
I created a project and added main_cnt.v in project, set as top module.
As I have `include in main_cnt.v, params.v should have been automatically get added under non module sources But its under  syntax error file and giving error for line 23 in param.v( parameter LENGTH = 5 ).
Also Its showing warning in main_cnt.v as `include directive not isolated on its own line.
