OpenCL kernel memory access issue: writing local memory at specific starting point
Hi there,
I am currently trying to write an OpenCL kernel that is able to update its local memory at specific points.
for example, when the kernel is initially deployed, the local memory is written in places 0 to 100. On the next deployment, I'm want to appened data to it at locations 101 to 120 and so on.
The curreny for loop that works and reads into local memory starting at 0 is the following:
voide krnl_name(__global int* bram_mem,const int BRAM_dim){
int local_bram_mem[4096];
int size;
size = BRAM_dim;
__attribute__((xcl_pipeline_loop))
read_bram_mem : for (int i=0;i<size;i++){
    local_bram_mem[i] = bram_mem[i];
The current kernel that we are trying to implement is the following, starting at a given value:
voide krnl_name(__global int* bram_mem,const int BRAM_start, const int BRAM_end){
int start,end;
start = BRAM_start;
end = BRAM_end;
read_bram_mem : for (int i=start;i<end;i++){
My question is, does OpenCL let me do the second for loop? When I try the second approach in simulation, it doesn't give us the correct results. But there are also no compilation errors. Does every for loop have to start at zero?
I am using SDAccel 2018.3
Re: OpenCL kernel memory access issue: writing local memory at specific starting point
The problem I was running into wasn't because of this. Performing the both types of for loops is acceptable in OpenCL in SDAccel 2018.3.
