Newbie ricvail
Our IP cores must be started 4 times before it produces output
Hello!
We tried to design a system that is supposed to perform a matrix multiplication, but it is behaving wierdly and we can't figure out what's going on.
This is the HLS code of our cores: https://pastebin.com/6mxeksig
This is our block diagram:
So, we tried executing this code from SDK: https://pastebin.com/DAEMtd9M
But we soon realized that this loop caused the program to get stuck:
while (!XMatrixjoiner_IsDone(&joiner));
Now, here comes the wierd part: if we launch 3 times the execution (as in we press 3 times the green button shown here:)
, the program just ends getting stuck on that loop, but the 4th time it somehow reaches the end of the main function and prints the correct results.
If we disable the cache (the commented lines) it stops working entirely.
Upon further examination, we fund out that if we put the two "start" calls in a loop that is executed 4 times (like this https://pastebin.com/uXbT2k5B ) then the program works every time.
So you could say that we did find a workaround, but this nonetheless is classified as unexpected behaviour, so I'd like to have some insight from the experts about what's going on.
Teacher muzaffer
Re: Our IP cores must be started 4 times before it produces output
@ricvail does cosim pass for the IP ? Does PL timing checks fully clear? Have you tried to debug the issue by putting in an ILA to see what happens to do done signal?
