Anonymous
Not applicable
Partial input delay
I have some trouble with a design that I need to implement into the Aritx 7 EVB.
I have added some timing contraints to the design for the clocks and also for the
input ports:
set_input_delay -clock CLK -min 1.000 PORT_IN
well as
output ports:
set_output_delay -clock CLK -max 1.000 PORT_OUT
But now I see partial input/output delays in the timing report.
It comes up in the Check timing window. It is same amount of ports that I have in there.
I am using an Artix 7 200T FPGA.
Help would be greatly appreciated.
Thx
Guide
Guide
Re: Partial input delay
You need to specify both a -min and a -max for both input and output delays.
Your current constraints specify a min only for input (which leaves the max unconstrained, hence a partial input delay). Similarly, for the output delay, you have only a max, which leaves the min unconstrained.
Avrum
Guide
Guide
Avrum
Anonymous
Not applicable
Thanks Avrum
That was very helpful.
