alexandre.solon
Portability:3 (run out of memory)
Hi everyone,
I've been trying to synthesize a project in EDK 11.1, but I am getting a portability:3 error message:
XST: Portability:3 This Xilinx application has run out of memory or has encountered a memory conflict...
XST stops right at the 2GB barrier, but my machine has 4GB of memory. I think that this might be a Windows 32-bit Physical Address Extension error.
Or perhaps, EDK 11.1 is limiting XST to 2GB.
I have already read lots of comments in the forum, but none of them has helped yet.
Do I really have to buy a 64-bit machine?
How can I optimize my project in order to reduce XST work?
Does the update to 11.5 fixes this problem?
Thanks in advance,
evgenis1
Advisor
Advisor
Windows allocates 2GB to user processes. You can set /3GB switch to enable 3GB - see this ms technet article
Hope that helps,
OutputLogic
mjl-0708
I install 4GB DDR3 memory on my computer(Windows XP 32bit SP3), and I edit the boot.ini file by adding /3GB /USERVA=3000(according #14932), but when I synthsis my design again, the same error also ocurs.
How can I fix it?
bassman59
Historian
Historian
How can I fix it?
You need a 64-bit OS and more memory. That's how you fix it.
