Gabriel_94
Post synthesis simulation problem
Hi, I'm Gabriel.
I'm trying to build a buffer to store matrix, which can write column data and read row/column data, respectively.
So I've designed the architecture with column-wise pipe registers with two data outputs for row and column data.
Row data is read by concatenated bits from column data.
The problem happens after synthesis that behavioral simulation shows proper functioning; however, post-synthesis timing/functional simulation shows that
the column input data doesn't store properly.
Outputs from buffer also wrong as the input isn't stored for the few first and few last addresses.
So, I judged that the synthesis might have removed some wires and registers, and that could have yielded such simulation results.
I've tried "(*keep = "true"*)" options, which didn't work.
I have no idea what could be done.
Please, help, and thank you in advance.
I'm attaching Verilog codes and the result of simulations to help to understand.
Thank you
calibra
@Gabriel_94
It is a bug.
The design synthesized with Mentor Graphics Precision simulate well.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
pulim
Hi  @Gabriel_94
Can you share PipeReg module also to reproduce this issue at my end?
In which version of vivado are you seeing this issue?
Can you try using DONT_TOUCH attribute and see if that helps?
Manusha
Gabriel_94
module PipeReg #(parameter  BITWIDTH = 1) (
    input   wire                        CLK,
    input   wire                        RST,
    input   wire                        EN,
    input   wire    [BITWIDTH-1 : 0]    D,
    output  reg     [BITWIDTH-1 : 0]    Q
    always @ (posedge CLK)
    begin
        if (RST)        Q <= {BITWIDTH{1'b0}};
        else if (EN)    Q <= D;
    end
Thank you for your reply.
-the version of the vivado
I'm using 2019.1 version of vivado at the moment.
Thank you for your advise, I will check if DONT_TOUCH attribute works and let you know!
Thanks again,
Gabriel
Gabriel_94
I have tried (* dont_touch = "true" *), it didn't work on post-synthesis simulation.
Thank you for your advice!
calibra
@Gabriel_94
It is a bug.
Gabriel_94
Thank you, I have checked on another simulation tool and worked fine.
Have a good day
