07-26-2011 07:55 AM
Hi all,
I have a quite complex design whereas one module has the following include definition at the beginning:
// Global header file includes
`include "sys.h" // system level definition file which contains the
// time scale definition
I have added the sys.h file to the project by right click on the project and then "add source" --->
browse to directory where sys.h is located. Adding it a second time fails, because it has already
been added to the design!
When I run sythesis with Xilinx XST 10.1.03 I get the following error:
ERROR:HDLCompilers:26 - "../design/sys/iop/sparc/tlu/rtl/tlu_rrobin_picker.v" line 30 Could not find verilog include file 'sys.h'
Analysis of file <"sparc.prj"> failed.
Anyone an idea why XST ISE fails to find sys.h?
Many thanks,
Richard.
07-26-2011 08:59 AM
ISE does not use the project files to find the `include files for Verilog. So in essence adding
sys.h to the project only gives you a convenient way to open it for editing. For include files that
are not in the project directory you need to add the path to the Verilog Include Directories
under the Synthesis Properties settings. If you use a command line flow the switch you
need is -vlgincdir
The Synthesis Properties dialog box allows you to browse to the directory to select it.
HTH,
Gabor
07-26-2011 08:59 AM
need is -vlgincdir
HTH,
Gabor
07-26-2011 09:09 AM
Brilliant Gabor, that did the trick ;)
08-20-2011 05:31 AM
ca you help me to intrgrate a .h file
