david.hoffman
Problem with Verilog system task $ceil
I'm having trouble using the $ceil system task.
I have the following parameters that define the number of bits used for a counter:
parameter BITS_PER_WORD = 32
localparam real BYTES_PER_WORD = BITS_PER_WORD / 8;
localparam real BYTES_PER_PACKET = 190;
localparam integer WORDS_PER_PACKET = $ceil(BYTES_PER_PACKET / BYTES_PER_WORD);
localparam WORD_CNTR_BITS = $clog2(WORDS_PER_PACKET);
These parameters resolve to the following values (from the Vivado synthesis log):
 Parameter BITS_PER_WORD bound to: 32 - type: integer
Parameter BYTES_PER_WORD bound to: 4.000000 - type: float
Parameter BYTES_PER_PACKET bound to: 190.000000 - type: float
Parameter WORDS_PER_PACKET bound to: 0.000000 - type: float
Parameter WORD_CNTR_BITS bound to: 0 - type: integer
I expect WORDS_PER_PACKET to be ceil(190.0 / 4.0) = ceil(47.5) = 48.0
And therefore expect WORDS_CNTR_BITS to be 6.
Furthermore, I would expect the type of BYTES_PER_PACKET to of type integer since it is explicitly declared as an integer but the tool is reporting it as a float.
Am I using $ceil incorrectly here?
David
david.hoffman
My original post was using Vivado 2018.2. When I upgraded to Vivado 2018.3 and compiled the same code the issue was resolved:
	Parameter WIDTH bound to: 32 - type: integer
	Parameter WORDS_PER_PACKET bound to: 48 - type: integer
	Parameter WORD_CNTR_BITS bound to: 6 - type: integer
I would have thought something like this would be caught in Xilinx's regression testing before release!
david.hoffman
