study3mouth
Process "Check Syntax" failed
I just installed ISE10.1 and create a very simple *.vhd.
When I click "Behavioral Check Syntax". the ISE shows the following information:
Started : "Check Syntax".
Running vhpcomp
Process "Check Syntax" failed.
I just wonder where is wrong? The *.vhd file I use has no problem as it can pass in another ISE system under another PC.
