Visitor jidawei123
Process "Synthesis" failed
Hi, i have one problem as follow,  could someone  give me some solution or ideas?
FATAL_ERROR:Xst:Portability/export/Port_Main.h:143:1.17 - This application has discovered an exceptional condition from which it cannot recover.  Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
:smileyhappy: thank you very much~
Observer kianoosh5
Re: Process "Synthesis" failed
Just as a fellow person that has struggled with this, i have learned that changing my design around has gotten around the problem.
Not enough info on particular error and it is so vague that you really do not know where to synthesize your design.
I have gone as synthesizing each module by itself and slowly bringing the other ones in .
This has worked for me. Not a logical error but wish you luck!
Observer kianoosh5
Visitor jidawei123
thank you very much, i will try again.
