lcasado
Question about --synthesis translate_on and translate_off
Hello all,
I am porting a project from Spartan-3A to Spartan-6 in ISE 13.4. When using the bbfifo_16x8.vhd (original from 2003) in the Spartan-6 project, I did have to remove the INIT attributes, because ISE was giving an error in those lines, but after that, I realized that ISE wasn't synthesizing this block. After looking for a reason in google, I got a 2010 version of bbfifo_16x8.vhd from Ken Chapman, where it appears a comment saying:
-- Version : 1.20
-- Version Date : 11th December 2006
-- Reason : Attributes and '--translate on/off' directives removed as no longer
--          required for XST.
My question is, why are this directives no longer supported? Why is it that the original source code worked for Spartan-3A and does not work for Spartan-6?
Thank you very much,
Lucky
nupurs
TRANSLATE_OFF and TRANSLATE_ON instructs the Synthesis tool to ignore blocks of code.
This can be useful to ignore source code that is not relevant for Synthesis, such as simulation code.
These attributes are given within a comment in RTL code. The comment should start with one of the following keywords:
  • synthesis
  • synopsys
  • pragma
TRANSLATE_OFF starts the section of code to be ignored, and TRANSLATE_ON ends the section to be ignored. These attributes cannot be nested.
Be careful with the types of code that are included between the translate statements.
If it is code that affects the behavior of the design, a simulator could use that code, and create a simulation mismatch.
Verilog Example
// synthesis translate_off
...Code to be ignored...
// synthesis translate_on
VHDL Example
-- synthesis translate_off
-- synthesis translate_on
Give kudos if it led you to the solution, accept as solution if it resolved your query.
Nupur
nupurs
  • synthesis
  • synopsys
  • pragma
Verilog Example
VHDL Example
Nupur
nupurs
In ISE Design Suite 11.2, XST introduced a new VHDL/Verilog parser for Virtex-6 and Spartan-6 families.
The new parser brings a lot of improvements to the XILINX Synthesis solution.
However, several constructs supported in the XST Standard version for older FPGA families (such as Virtex-5 and Spartan-3) are not VHDL/Verilog LRM compliant.
Some of them are rejected by the new parser and some of them are interpreted differently.
Such situations will require some VHDL/Verilog code changes to successfully process the design using the new parser.
Also, refer to following Answer Records:
http://www.xilinx.com/support/answers/32927.html
http://www.xilinx.com/support/answers/32974.html
Nupur
lcasado
Thank you very much for your invaluable help!
