RAM-Based FSM Synthesis in vivado
I was wondering if vivado has an option to synthesis the FSM to memory units (ROM or BRAM)?
By searching through the forum I found out that XST has this option (by setting FSM_STYLE to bram) but I could not find anything in vivado user guideline that shows that option is available in vivado as well! Does vivado no longer supports RAM-based FSM synthesis or is it available under another name?
Thank you!
Tags (2)
Re: RAM-Based FSM Synthesis in vivado
Hi @shadiasd
Like in ISE, in vivado we don't have any attribute that supports RAM based FSM.
check this ARs
https://www.xilinx.com/support/answers/60799.html
Thanks and Regards
Balkrishan
I have posted my query in the wrong board by mistake,  "Welcome & Join" instead of "Synthesis" board.
As I understood  I am not able to delete my post as a newbie. I appreciate it if someone with a higher rank can move it to the "Synthesis" board (Xilinx Products : Design Tools : Synthesis) please.
Thank you very much!
Thank for the quick reply @balkris. I have actually seen that post before, but unfortunately that does not talk about FSM_STYLE attribute. The other attributes that are mentioned there are not related to synthesising the FSM to BRAMs.
Hi @shadiasd
It seems there is no workaround to use fsm_style attribute in Vivado. CRs reported on this issue
Thanks and Regards
Balkrishan
Re ISE ,
there was a use ram for state machines,
its in the advanced property
https://www.xilinx.com/itp/xilinx10/isehelp/pn_c_setting_advanced_properties.htm
https://www.xilinx.com/itp/xilinx10/isehelp/pp_db_xst_hdl_synthesis_options.htm
Very useful, much missed in Vivado.
But I'm certain in Vivado "it can be done in TCL".
Advisor
Advisor
Dr. J
Your sarcasm is greatly appreciated.
DSP in hardware and software
