Newbie chen18wijn@
RAM_MODE attributes
I would like to know if there’s a way to infer a Block RAM as SDP using attributes. In the document UG473 page 35 it says specifically that there are attributes for this purpose, but I couldn’t find an example for that.
Thank you.
Re: RAM_MODE attributes
You can refer to "RAM_STYLE" attribute in UG901.
chen18wijn@
I believe the UG473 is discussing the primitive based attributes and not the RTL inference based primitives:
Above snapshot was taken from language template of Vivado.
In RTL you can guide the tool by using RAM_STYLE whether you want to infer BRAM or not, and based on RTL description and read-write structure, synthesis engine will infer the memory as SDP/TDP.
Anusheel
Hi chen18wijn@
Welcome to the Xilinx Forum!
Xilinx document UG473 mostly discusses use of the RAM primitives (RAMB36E1 and RAMB18E1) to get block-RAM into your project.  This is not a very popular method.
Another way to get block-RAM (SDP in your case) is to infer it using the code examples found on pages pages 117-120 of Xilinx document UG901.  You can simply copy the code examples from UG901 into your project  -or-  on page 110 of UG901, you will find a link called "Coding Examples" that enables you to download the file, ug901-vivado-synthesis-examples.zip, with the code examples.
Finally, you can get block-RAM by using the Xilinx IP called the Block Memory Generator that is described by Xilinx document PG058.
In most cases, I prefer to infer block-RAM using the UG901 coding examples - since this helps keep my code portable.
Cheers,
Mark
