kardec
RTL Schematic Viewer: connection ended in corner
Hi guys, does it has any special meaning if a connection ends in a corner?
As you can the red line makes a 90º corner just before it connects to the port. Am I doing anything wrong? does it have any meaning?
Thanks in advance!!!
syedz
@kardec,
No, I do not think the 90 degree cut would make any difference.
Can you refresh the schematic and see if it changes and also search the cell pin name which is connected to a(7:0) and double click on the cell pin.
--Syed
anusheel
@kardec
RTL view just shows the connection of nets, primitives and blocks. "red line makes a 90º" just shows a connection and it has nothing to do with the RTL functionality.
Anusheel
