Visitor abiliocamelo
RTL Schematic close the Vivado 2017.4
After writing the Verilog code, and running the behavioral simulation without problems, when I try to see the schematics with RTL Schematics, Vivado closes without any indication of error.
What will be the problem?
Scholar hbucher
Re: RTL Schematic close the Vivado 2017.4
@abiliocamelo see if this helps
https://www.xilinx.com/support/answers/55854.html
Hi @abiliocamelo,
Make sure you use the recommended operating systems for Vivado 2017.4 (link). Then initially try to narrow down if this crash observation is machine specific or design specific (try to reproduce the crash with tool example designs).
Prathik
Please mark the appropriate post as an answer "Accept as solution" in case it helps to resolve your query.
