Reading file in vhdl when synthesis
Is it possible to read a file for initializing signal value in VHDL when synthesis?
The code could be like the following (please ignore the VHDL grammer error):
entity
port(
 clk : std_logic,
 di : in std_logic,
do : out std_logic,
end entity
architecture of xxx is
--function to read file
function get_file_value(file_name : string) return integer;
function get_file_value(file_name : string) return integer is
   variable b : integer;
  variable fn : FILE;
begin
    open_file(fn, file_name)
    b := read_file(fn)  --reading some data from file
    return b;   -- b is kind of content from the file.
end function;
----init a value from file content.
constant init_value : inteer = get_file_value("c:\data.txt");
signal  xxxx;
begin
   process
   begin
       wait until rising_edge(clk);
       do <= init_value;
  end process;
end archetecture;
I tested above code and realised the function was run but no result read from that file.
Thanks in advance.
Professor
Professor
Re: Reading file in vhdl when synthesis
I'm not a VHDL expert, but you should be able to do what you want.  Did you get any errors or warnings during synthesis?  One thing I noticed is you used a backslash in the path name.  I would expect you to get some sort of error or warning that the file wasn't found because of that.  Even running in Windows, path names should have normal slashes, not backslashes.
-- Gabor
good ask
only i know is that you can do that in IP core for RAM
I am tired of the traditions of peoples --
All I want is to live freely with the girl which I love --
But this is impossible because the traditions of the people stronger than me.
Can you check the example in the XST synthesis user guide page 235?
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/xst_v6s6.pdfe and see if that helps?
Achutha
Thanks a lot, Achutha.    That is exactly what I need.  I will try if it works.
