Reg: Synthesis Error in Hamming Decoder Verilog Coding
module hamm_dec(rst,en,dec_in,dec_out,err_corrected);
input rst,en;
input [1:12]dec_in;
output reg[1:4]dec_out;
output [1:12]err_corrected;
reg [1:12]temp_err_corrected;
reg [1:12]temp;
reg [1:4]temp_out;
reg h_matrix[1:12][1:4];
integer i,j,k,l;
integer f1,f2,f3;
initial
begin
f1=$fopen("h_matrix.txt","r");
f3=$fopen("h_matrix_out.txt","w");
end
always @(rst or en or dec_in) begin
if (!rst) begin
dec_out <= 0;
temp <= 0;
temp_out <= 0;
temp_err_corrected <= 0;
end else if (rst && !en)begin
temp_err_corrected <= dec_in;
for (i=1;i<=12;i=i+1)
begin
for (j=1;j<=4;j=j+1)
begin
f2=$fscanf(f1,"%b",h_matrix[i][j]);
end
end
end else begin
for (k=1;k<=4;k=k+1)
begin
for (l=1;l<=12;l=l+1)
begin
temp[l] = dec_in[l] & h_matrix[l][k];
temp_out[k] = ^temp;
end
end
dec_out <= temp_out;
temp_err_corrected[temp_out] <= ~(dec_in[temp_out]);
end
end
assign err_corrected=temp_err_corrected;
endmodule
Error:
Analyzing top module <hamm_dec>.
ERROR:Xst:2333 - "../../../../../shilpha.G/FFT CODING/Hamming_code/hamm_dec.v" line 57: File argument of function $fscanf is not constant.
ERROR:Xst:2634 - "../../../../../shilpha.G/FFT CODING/Hamming_code/hamm_dec.v" line 66: For loop stop condition should depend on loop variable or be static.
WARNING:Xst:905 - "../../../../../shilpha.G/FFT CODING/Hamming_code/hamm_dec.v" line 33: One or more signals are missing in the sensitivity list of always block. To enable synthesis of FPGA/CPLD hardware, XST will assume that all necessary signals are present in the sensitivity list. Please note that the result of the synthesis may differ from the initial design specification. The missing signals are: <f1>
anusheel
vincybeaulah@1 Please do not post same query multiple times.
Anusheel
