Observer aparna
Regarding modulus and division operators
Can I please get some help with this code?
Its simple but I am not able to use modulus operator or the division operator?
Library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
use IEEE.NUMERIC_STD.ALL;
entity modcheck is
Port ( a : in STD_LOGIC_vector(3 downto 0):="1000";
b : in STD_LOGIC_vector(3 downto 0):="1100";
c : out STD_LOGIC_vector(3 downto 0));
end modcheck;
architecture Behavioral of modcheck is
signal p,q:integer;
begin
p<=conv_integer(a);
q<=conv_integer(b);
c<=a mod b;
end Behavioral;
Is there a reason i am unable to use this modulus operator? are there any library files missing?
Pl lemme know
Thanks a ton
Aparna:)
Historian
Historian
Re: Regarding modulus and division operators
@aparna wrote:
Library IEEE;
entity modcheck is
end modcheck;
signal p,q:integer;
begin
p<=conv_integer(a);
q<=conv_integer(b);
c<=a mod b;
end Behavioral;
Pl lemme know
Thanks a ton
Aparna:)
First of all, don't use std_logic_arith, and don't use conv_integer. You should use the numeric_std functions (you've already used numeric_std, anyway).
p <= to_integer(unsigned(a);
q <= to_integer(unsigned(b);
Next, the integers p and q should be ranged; otherwise, they're 32 bits which might be too big.
Third, you convert a and b to integers p and q, yet your mod operation is on a and b. That seems like a mistake.
Finally, to actually answer your question. Read the fine synthesis guide. The division and mod operators are not supported except when the divisor (q) is a power-of-two. Furthermore, I haven't used the mod operator for anything other than to ensure that counters roll over properly, so I'm not sure if the result of a mod operation like you're doing will synthesize.
Teacher rcingham
I heartily concur with bassman59's wise words.
Furthermore, for synthesis (at least up to 13.2) the second parameter of the 'mod' operator must be a CONSTANT value, which restriction is currently causing me considerable grief.
Recently there's been other posts about div & mod operations...
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Historian
Historian
Just as a datapoint, Synplify also requires the second parameter of mod to be a constant. Synthesizing a non-constant divisor probably gets very icky very quickly.
