Relative paths for vivado simulation and synthesis
I need file access in my verilog code. ./ works at top level of project for modelsim, but is down three levels into the Vivado sim hierarchy. I have no idea where synth is looking. Pwd in the tcl console shows some obscure user location.
Not quite the right issue. I'm doing readmemh to build a ROM and can't find the hex files. Setting the include directory had no effect. I wound up with 3 ifdef's as shown. Not elegant, but functional.
`ifdef MODEL_TECH // each compiler wants the hex files in a different place
bit [15:0] Path = "./";
`elsif XILINX_SIMULATOR
bit [71:0] Path = "../../../";
`else
bit [47:0] Path = "../../";
`endif
assign q = BitReg;
initial begin
$readmemh({Path, "SRC/BitMaps/File1.hex"}, Bitmaps, 32'h00000, 32'h00FFF);
You can find below options in simulation settings. Refer below snapshot:
Anusheel
Helpful answer -> Give Kudos
Check the below article http://www.xilinx.com/support/answers/54006.html
Deepika.
Deepika.
`else
`endif
assign q = BitReg;
initial begin
We  have struggled with different tool path issues many times in past projects and tool flows. Our latest solution for readmemh file path names uses two steps:
1) From our script or GUI tool, we set a "PROJECT_ROOT" define. For example, in Vivado Synthesis Settings:
    PROJECT_ROOT=/myPath/projectDirectoryTop
or from command line for our simulator
    +define+PROJECT_ROOT=/myPath/projectDirectoryTop
2) In the rtl source, we append a relative path from the project root
        parameter INIT_FILE = {{`PROJECT_ROOT},"/rtl/module/mem512x8.mif"}
(this exact syntax worked with our simulator and all our versions of XST and Vivado.
If you don't need to use all those different tool versions, there are simpler variations on the syntax).
So the net result of this is:
a) the project root is evaluated by our script whenever we start a simulation or synthesis run (effectively relative path)
b) simulation and synthesis tools see a full absolute path to memory files (no chance to make a mistake)
