Remove the "target" tag from xdc
My env - Win7, Vivado 2018.3
I get a warning message as:
[Constraints 18-5210] No constraints selected for write.
Resolution: This message can indicate that there are no constraints for the design, or it can indicate that the used_in flags are set such that the constraints are ignored. This later case is used when running synth_design to not write synthesis constraints to the resulting checkpoint. Instead, project constraints are read when the synthesized design is opened.
Is it due to my setting of the ac701_ethernet_rgmii_example_design.xdc as "target"?
How can I remove the "target" tag?
Re: Remove the "target" tag from xdc
Hi, @gin_xil ,
Does the current file have the Write permission?
You can try to create a new XX.xdc and set it as "Target" constraint.
To remove the "target" tag: set_property target_constrs_file "" [current_fileset -constrset]
@hongh,
I don't know.
But I removed that xdc and re-added the xdc and the "target" tag was gone.
I re-Implemented my design by that Warning with "No constraints selected for write" still remains. What shall I do?
Hi, @gin_xil ,
The XDC file with "Target" Tag means that the new involved constraints will be saved in this XDC file.
So you should have a XDC file with "Target" Tag, which can be read & write.
If the issue still occurs, you can try to recreate the project.
