Resource utilization per signal
is there a way to get the resource utilization on a per signal basis?
I mean, if there are a few bad coded lines, Vivado will report net xy needs about 5000 CLBs?
Franz
Re: Resource utilization per signal
Hi, @franzforstmayr ,
Vivado can report the module level utilization, and it's an odd requirement to report utilization based on nets.
You can try to report the cells driven by the net.
I'll have to try this out!
Scholar dgisselq
When optimizing pieces of code, I will often separate that code into a module by itself and run Yosys on it with the following script:
read -sv module.v
synth_xilinx
stat
That will return a good estimate of the resources used by the module, without needing to connect all of the various exterrnal wires/ports up to valid external pins, and also without needing to specify which 7-series part you are using.
Dan
Hi, @dgisselq ,
It seems synthesizing the single sub-module one-by-one isn't efficient enough when you have hundreds of modules in your design.
You can also check the result of report_utilization of the top design to get the similar information.
@franzforstmayr
I would prefer to look into the synthesis log file to check for warnings and info. In many scenarios, the tool will write a message in the log file when an incorrect coding style is used. For example, bad memory code may result in " too sparse and won't be mapped to RAM"
