Observer zanabonir
Reuse Synthesis
Dear Forum
In my desing Im using different IP, where only one of them (a BRAM) need much time for Synthesis...Other IP are "little"
Total time is around 30min circa.
When I modify one of the little IP, also very simple modification, and relaunch the Synthesis, again this process take long
time...Seems that Vivado re-Syntetize the BRAM IP that has been not changed.
Question is if there is a way to tell Vivado to use old resut of IP mot modified.
Thanks again
Roberto
Re: Reuse Synthesis
Hi @zanabonir,
The Out of context option is available in later tools. Why not using a more recent version of vivado?
Note: In your case, you have a black box. The solution is nearly this. You would need to synthesis the BRAM alone and then export the synthesis result (using a netlist). Then on the netlist you can disable used for synthesis.
However, it is simpler to use vivado 2017.4.
Florent
Re: Reuse Synthesis
Hi @zanabonir
By default Vivado uses IP cache option which enables IP to use already synthesized results referencing the cache and copies the synthesized results. Refer page 14 below link:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug896-vivado-ip.pdf
Rohit
Rohit
Observer zanabonir
Re: Reuse Synthesis
Thanks Mr Rohit for reply.
When I choose Project Manager -->Project Setting-->IP->IP Cache-->Disabled ( is the default), the Syntesis take circa 40min.
Then:
    - I change in .......-> Local (folder is in my project )
    - modify another very little IP ( not the big IP responsible for the long time Synthesis)
    - let inalterate the big IP
    - Launch Syntesis of all project
the time is again the same (circa)..So dont work.
Info:  - I did not touch the cache setting of every single IP
         -I not syntetized every single IP, but only all project
Roberto
Re: Reuse Synthesis
Hi @zanabonir,
Did you try to set your BRAM as Out-of-context for synthesis?
This way if you do not change it, it won't be re-synthesized.
If think this is what you are looking for.
Florent
Observer zanabonir
Re: Reuse Synthesis
Thanks for reply
In Vivado 2015.3 I cant find this option .
I find another similar, in the Property window, where I -unceck- the   -Used for Syntesis -
In effect, regenerating the OOC files, the IP is not anymore Syntetisez...with a big save of time.
Unlucky, a error message arrive in the -Implementation step-, saing this (about the big BRAM that I not syntetized) :
Cell ..../BD1_IP_Ram  has undefined contents and is considered a black box.
The contents of this cell must be defined for opt_design to complete successfully.
I was one step from solution....hhhh
Thanks again
Roberto
Re: Reuse Synthesis
Hi @zanabonir,
Florent
Observer zanabonir
Re: Reuse Synthesis
Thanks Again
I install the 2017.4  and seems work without problem.
Seems that Vivado recognize -alone- what IP has been modified,and when running  the Synthesis,Vivado
first regenerate the OOC  of  only the IP modified, then start the global Syntesis....
Thanks for all replies
Roberto
