Reusing registers in VHDL FSM code
I need to write a Finite State Machine (FSM) in VHDL code and want to have several computations being processed at the same time (a standard pipeline). In every state I have several operations to be calculated and I employ registers for the result of each one. I strongly need to reuse these registers, for example: Register 1 is filled in State 1 (as a result of a multiplication) and it is used in the State 2 and State 3 (as parameter of other operations), then in the State 4, I want to save a new operation result (another multiplication) in Register 1 reusing it.
My code works in Simulation in Xilinx Vivado 2019, but when I implement the desing in a real FPGA (Basys 3 Artix-7) it doesn't work. I realized that the problem is that the correct values are not saved when I reuse the registers. Sometimes, the first time I reuse them, they keep the correct value, but already in the second reuse in later FSM states, the stored values are not correct, I mean, they do not correspond to the result of the operation that I am trying to save in the register.
Next, an example of my FSM design:
LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.numeric_std.ALL;
ENTITY test1_arith IS
GENERIC (
ap_bit_width : positive := 4;
ap_latency : positive := 2
PORT (
I1 : IN STD_LOGIC_VECTOR(ap_bit_width - 1 downto 0);
I2 : IN STD_LOGIC_VECTOR(ap_bit_width - 1 downto 0);
I3 : IN STD_LOGIC_VECTOR(ap_bit_width - 1 downto 0);
O1 : OUT STD_LOGIC_VECTOR(ap_bit_width - 1 downto 0);
ap_clk : IN STD_LOGIC;
ap_rst : IN STD_LOGIC;
ap_start : IN STD_LOGIC;
ap_done : OUT STD_LOGIC;
ap_idle : OUT STD_LOGIC;
ap_ready : OUT STD_LOGIC
END;
ARCHITECTURE test1_arith_arch OF test1_arith IS
ATTRIBUTE CORE_GENERATION_INFO : STRING;
ATTRIBUTE CORE_GENERATION_INFO OF test1_arith_arch : ARCHITECTURE IS "Test,VHDLbyMOEA,{HLS_SYN_LAT=2}";
CONSTANT ap_const_logic_1 : STD_LOGIC := '1';
CONSTANT ap_const_logic_0 : STD_LOGIC := '0';
TYPE state IS (state_1,state_2,state_3);
SIGNAL state_present: state;
SIGNAL state_future: state;
SIGNAL Flag: Integer:=0;
--Signal RF : STD_LOGIC_VECTOR_array;
FUNCTION ALU ( Op: IN integer range 0 TO 23;
A, B: IN STD_LOGIC_VECTOR (ap_bit_width - 1 downto 0) )
RETURN std_logic_vector is variable Result : std_logic_vector(ap_bit_width - 1 downto 0);
variable A_int: Integer:=0;
variable B_int: Integer:=0;
variable Result_int: Integer:=0;
begin
A_int := to_integer(unsigned(A));
B_int := to_integer(unsigned(B));
With Op Select Result_int:=
to_integer(unsigned(NOT A)) When 0,
to_integer(unsigned(A AND B)) When 1,
to_integer(unsigned(A OR B)) When 2,
to_integer(unsigned(A NAND B)) When 3,
to_integer(unsigned(A NOR B)) When 4,
to_integer(unsigned(A XOR B)) When 5,
to_integer(unsigned(A XNOR B)) When 6,
(A_int + B_int) When 7,
(A_int - B_int) When 8,
(A_int * B_int) When 9,
(A_int / B_int) When 10,
ABS(A_int) When 11,
(A_int ** B_int) When 12,
(A_int MOD B_int) When 13,
to_integer(unsigned(A) & unsigned(B)) When 14,
to_integer(unsigned(A) SLL B_int) When 15,
to_integer(unsigned(A) SRL B_int) When 16,
to_integer(unsigned(A) SLA B_int) When 17,
to_integer(unsigned(A) SRA B_int) When 18,
to_integer(unsigned(A) ROL B_int) When 19,
to_integer(unsigned(A) ROR B_int) When 20,
to_integer(unsigned(A) & unsigned(B)) When 21,
to_integer(unsigned(A) & unsigned(B)) When 22,
0 When others;
return STD_LOGIC_VECTOR (TO_UNSIGNED (Result_int, (ap_bit_width)));
END FUNCTION;
SHARED VARIABLE R1:std_logic_vector(ap_bit_width - 1 downto 0);
BEGIN
OP_FSM : PROCESS (state_present)
BEGIN
CASE state_present IS
WHEN state_1=>
R1 := ALU(Op => 7 ,A => I1,B => I2);
Flag<=1;
IF (Flag=1) THEN
state_future <= state_2;
END IF;
WHEN state_2=>
R1:= ALU(Op => 7 ,A => R1, B => I3);
Flag<=2;
IF (Flag=2) THEN
state_future <= state_3;
END IF;
WHEN state_3=>
O1<= ALU(Op => 7 ,A => R1,B => "0001");
Flag<=3;
IF (Flag=3) THEN
state_future <= state_1;
END IF;
END CASE;
END PROCESS OP_FSM;
CLK_FSM : PROCESS (ap_clk)
BEGIN
IF (ap_clk = '1' AND ap_clk'EVENT) THEN
state_present <= state_future;
END IF;
END PROCESS CLK_FSM;
END test1_arith_arch;
In this case, I want to reuse R1 and it works well in Simulation with Xilinx Vivado (1 + 4 + 0 + 1 = 6):1.png
Unfortunately, in the Basys 3 FPGA Artix-7 I don't get the correct results:2.png
In this figure, I show the Case 10 in a FPGA, it should get 6 (1 + 4 + 0 + 1) as result, but it gets 14 instead:3.jpg
In the tests that I have been doing I realized that it works better when before assigning a new value in the registry the value of the record is made zero before reassigning a value, for example:
WHEN state_3=>
R4<="0000"
IF( R4 = "0000") then
R4<= ALU(Op => 7 ,A=> R2,B=> R3, C =>"0000");
Flag <=3;
IF (Flag =3) THEN
state_future <= state_4;
END IF;
END IF;
Using this form I can reuse a register once, the second time I want to reassign a value to the register, incorrect values are shown in the output.
I declarated the registers as SHARED VARIABLE and SIGNALS and I have the same problem with both.
I appreciate any suggestion or idea, thanks a lot.
Ok. Lets start.
1. there is basically no need to EVER use shared variables. Apart from the fact from VHDL 2002 a shared variable must use a protected type (which is not synthesisable) they also can be a bit unpredicable if you're not 100% sure how your code is going to map to hardware. Also, because of the way a shared variable works, it cannot trigger a process, and so it may not behave on hardware as it does in simulation.
2. I would basically NOT have the ALU as one big function.  Putting it in a function means you cannot pipeline it.
2. R1/O1 etc are NOT registers, because they are output from an asynchronous process. This will be the same whether signal or shared variable.  You process is also missing some signals from the sensitivity list. Because its an asynchronous process, and you're clearly using VHDL 2008, you can use process(all). Maybe then your simulation will behave like the hardware.
4. You're creating latches because O1/R1 etc are not assigned in all states. If you want them registered, they need to be in a clocked process.
Clocking everything may be a really good idea. Using a 2 process state machine is a very old teaching style that still prevails and gives all the pitfalls above. Its still around because about 20 years ago synth tools were pretty dumb and needed combinatorial and register logic in separate processes. This has not been needed for >15 years (as long as Ive been in industry) but lots of engineers got used to the style and a lot of lecturers never updated their notes. A single process state machine will avoid all the above pitfalls.
Thank you so much, I'm going to modificate the code y prove it in the FPGA device.
