Simple UART Interface
Hi all,
I am trying to implement a very simple uart. Terminal output is inconsistent and I can't seem to spot the error. Code below;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity uart is
Port ( clk	: in STD_LOGIC;
		 tx : out STD_LOGIC);
end uart ;
architecture Behavioral of uart is
signal counter : unsigned ( 11 downto 0) := (others => '0');
signal shift : std_logic_vector(39 downto 0) := x"48454c4c4f";
begin
   tx  <= shift(39);
process(clk)
   begin
	if rising_edge(clk) then
		if counter = 5 then
			counter <= (others => '0');
			shift <= shift(38 downto 0) & shift(39);
		else
			counter <= counter+1;
		end if;
	end if;
   end process;
end Behavioral;
Any ideas ?
Re: Simple UART Interface
what speed is your clock?
assuming you are running in 8N1 mode, every byte needs 1 start bit, 8 data bits and 1 stop bit. Are you supplying those in your code?
clock is 50Mhz I am using 9600 baud rate 8n1. new code below still not working ;
library IEEE;
entity uart is
end uart ;
signal counter : unsigned ( 12 downto 0) := (others => '0');
signal shift : std_logic_vector(7 downto 0) := "00000001";
begin
   tx  <= shift(7);
process(clk)
   begin
		if counter = 5206 then
			shift <= shift(6 downto 0) & shift(7);
		else
		end if;
	end if;
   end process;
end Behavioral;
the counter max is 5207 but it doesn't matter much. I think the main issue is that you are still generating 8 bits. You should be generating 10 bits (Start, 8 data, stop).
same behavior, nothing is on the terminal.
what do you have as the middle 8 bits? put a visible ascii char there.
of course this assumes you did the tx pin assignment properly.
I have '00000001' as middle 8;
library IEEE;
entity uart is
end uart ;
signal shift : std_logic_vector(9 downto 0) := "1000000011";
begin
   tx  <= shift(9);
process(clk)
   begin
			shift <= shift(8 downto 0) & shift(9);
		else
		end if;
	end if;
   end process;
end Behavioral;
It can be seen from the code as well.
That's not going to print anything. Try 0x41 has the middle 8 bits.
Are you suggesting to type hex to logic_vector ?
try "0010000011" as your constant.
And check your pin assignment.
There is output but it's all weird characters ?
