Visitor splee
Simple code.. pls help
I am a beginner of VHDL.
I wrote a simple code below. The compiler warns me that 'b' should be in the sensitivity list. Why is this so?
Would the synthesis be different if I include b in the sensitivity list?
entity simpleBuffer is
    Port ( a : in  STD_LOGIC;
           c : out  STD_LOGIC);
end simpleBuffer;
architecture Behavioral of simpleBuffer is
signal b    : STD_LOGIC;
begin
    process (a)
    begin
            b <= a;
            c <= b;
    end process;
end Behavioral;
Historian
Historian
Re: Simple code.. pls help
@splee wrote:
           c : out  STD_LOGIC);
end simpleBuffer;
begin
    process (a)
    begin
            b <= a;
            c <= b;
    end process;
end Behavioral;
If you're a VHDL newbie, you should stop what you're doing and buy a copy of Ashenden's "Designer's Guide To VHDL." Everything you are asking is answered in that nice book.
Instructor
Instructor
The simple answer to the question is no, synthesis will not be different if you add b to
the sensitivity list.  On the other hand simulation may be different.  I'm not fluent enough
in VHDL to know whether the assignment "c <= b" takes the value of b before or after
the assignment "b <= a" above it.  If this were Verilog, the previous value of b would be
assigned to c.  So in effect the simulation would behave differently if you add b to
The reason you get a warning, is that for synthesis all right-hand-side variables
are assumed to be in the sensitivity list, so if any are missing you have the
potential for a mis-match between simulated and synthesized behavior.  As I
said it isn't clear to me whether this is one of those cases, but you will get the
warning regardless.
Obviously since you always simulate code before synthesis, you can see for
yourself whether the simulation behavior changes with the addition of b.
-- Gabor
-- Gabor
Visitor splee
Hi Bassman59,
Now I understand that:
- all signals on the right hand side of the "<=" must be in the sensitivity list
- synthesis tools ignore sensitivity list, anyway
My one question would be:
In a process statement, a signal only gets its assigned value after the process suspends, eg. in Behav1, b only gets the value of a after the process suspends. Why would a synthesis tool make it such complicated? I mean, why can't a signal  get the value immediately, just like variable and like in C program? What's the point of making things difficult?
Teacher eteam00
Here is an excellent explanation of blocking and non-blocking assignments.  It is written for Verilog, but the same principles and similar constructs apply to VHDL.
                                 assignments
language   blocking  non-blocking
Verilog       =         <=
VHDL         :=         <=
-- Bob Elkind
SIGNATURE:
Summary:
Advisor eilert
Advisor
Hi all,
the assignment comparision table has one little flaw. (But it is intended for learning verilog, so it is OK)
The := assignment in VHDL is for variables, and variable values can not leave the process, they are local.
Still, a good mixture of using variables and signals can be applied to splee's problem:
-- signal b    : STD_LOGIC; -- not necessary, since it will only be used in the process
begin
    process (a)
      variable b    : STD_LOGIC;
    begin
            b := a;
            c <= b;
    end process;
end Behavioral;
For simulation:
Now the process gets triggered by changes on signal/port a. Variable b is updated immediately and then assigned to signal/port c.
I may mention that some simulators have difficulties at showing variable values. Sometimes these are even optimized away. Be aware of this when simulating.
For synthesis, there is no difference.
____
About splee's question: "What's the point of making things difficult?"
The language isn't making things difficult. It's a computer language and so it does just what you tell it to do.
Also you are describing hardware, so the language needs a way to model hardware behavior.
That's why there are signals with their special behavior.
Signals and sensitivity lists together are a very simple way to deal with the problem of concurrency.
All processes (and concurrent assignments and instances) are working concurrently just like hardware does, and the simulator needs to handle this in a sequential way, since it runs on a CPU.
Have a nice synthesis
  Eilert
Teacher eteam00
Thanks for the help, Eilert.  I clearly know too little about VHDL to be explaining it to someone else.
Good explanation!
-- Bob Elkind
SIGNATURE:
Summary:
Teacher rcingham
To keep our pay rates moderately high...
Instructor
Instructor
Actually if the language is difficult, synthesis takes the easy way out by ignoring the
sensitivity list.  However, the list was not intended to make things difficult.  In fact it was
to make simulation simpler because the simulator is told which events need to
wake the process.  Some day XST will support the 2008 extensions to VHDL and
you will be able to use the "all" keyword to automatically place all right-hand side
signals in the sensitivity list.
-- Gabor
Also you might want to look into the history of VHDL and Verilog.  Neither language
was originally intended for synthesis.  That came later.  And it's still maturing, in
that synthesizers are continuing to add more of the language to their list of
synthesizable constructs.
-- Gabor
RE: making things difficult:
Because if it updated immediately, and you read it in another process, you'd get race conditions, just like in Verilog if you use the wrong type of assignment. In VHDL you *can't* make that mistake as anything you use to communicate with another process is a signal which has (by definition) non-blocking semantics. http://www.sigasi.com/content/vhdls-crown-jewel
Martin Thompson
martin.j.thompson@trw.com
http://www.conekt.co.uk/capabilities/electronic-hardware
Historian
Historian
@splee wrote:
Hi Bassman59,
Why is it so complicated? It's not that the synthesis tool makes it complicated -- this concept is for simulation.
And it is intended to model real hardware. The scheduling of assignments and delta time concepts are one way of making sure of this. The point is that everything on the right-hand side of an assignment has to "settle" before the assignment can be completed.
