Participant bjackson_ost
Stuck in synthesis
I'm currently using Vivado 2017.3.1 and targeting a Virtex 7 part (xc7v2000tflg1925-1). The design takes ~30% of the device. I'm running into a synthesis issue where the synthesis cycle gets to the end and the last entry in the Log is as follows:
INFO: [Common 17-206] Exiting Vivado at Wed Aug 1 16:20:24 2018...
I've been stuck here over 2 hours (as of this message posting). Does anyone have any suggestions on how to resolve this. My laptop information is as follows:
Toshiba Satellite P750
Intel Corei7
64 bit
Re: Stuck in synthesis
Hi, @ bjackson_ost ,
Could you try to run synthesis in the Vivado 2018.2?
Are you using GUI project or Tcl script?
Could you post your Synthesis log/report file?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
@bjackson_ost
Could be an intermittent issue, Can you try restarting your machine and rerun vivado synthesis?
--Syed
@syedz Yes, the issue sometimes goes away when I restart my laptop or restart Vivado.
@ hongh. I'm using the GUI. I'll post the log file should I encounter the same issue.
@bjackson_ost,
can you run process monitor and check for any additional files which causes synthesis to stuck?
https://docs.microsoft.com/en-us/sysinternals/downloads/procmon
Is this specific to one project or for all the vivado projects?
--Syed
@viviany
I'm using the GUI. I'll post the log if I have the same issue.
@syedz
This happens to this specific design. I'll try that process monitor and let you know. The design I'm working on is a mix of both VHDL and Verilog. Some of the Verilog sub designs have Verilog header files.
@syedz
I installed the process monitor you suggested. I ran synthesis and this time it's stuck on the "Loading part: xc7v2000tflg1925-1" phase. I checked the process monitor in real time and notice what I think is strange. It looks like a continuous loop where the same group of files are being created and closed. Specially, under the "Operation" column, there's a "CreateFile-CloseFile" continuous loop. Strange. Thoughts/suggestions?
@syedz@viviany@hongh,
It looks like I had to exit Vivado a few times and restart/shutdown my laptop. It's intermittent and I think the size of my design (~30% utilization) contributes.
@bjackson_ost
1. We need to first understand whether this is a design issue or machine specific issue. Can you try to run the same design on other machine?
2. Can you check .runs/Synth_1 folder and see whether the .dcp file got generated or not? If generated, try to use it for implementation phase as a temporary work around.
3. If you are able to see the same issue on other machines as well, can you share the project archive with us? I will setup an EZmove for file sharing.
Anusheel
