Synplify attributes
I want to use synplify attributes such as syn_keep and syn_preserve for a Vivado 2017.4 project.
For that I'm calling the synplify library as follows:
library synplify;
use synplify.attributes.all;
But I'm getting an error during compilation  [Synth 8-4169] error in use clause: package 'attributes' not found in library 'synplify'
I checked in the installation directory of Vivado and I found a vhdl package synattr which is defining the attributes package of synplify library.
Do I miss something?
Thank you
Mentor
Mentor
I think you need to add the file "synattr.vhd" to the project explicitly.    I don't think Vivado is searching that directory and loading the package just based on the library declaration alone.    This only works for IEEE packages,  I think.
Hello @jmcclusk
When trying to add this file to project it won't (i.e. it doesn't appear in the source list), it's like if the tool prevent me doing so.
So I guess there is another way to do
